trailer security
   / trailer security #1
workinallthetime
Veteran Member
Tulsa, ok
L45 TLB, ZD326P
anyone have any good ideas or bright inovations for locking a trailer up at home? seems like anything that locks in the trailer hitch can be bypassed with a short link of chain and a truck that sits up high.
i was thinking of an anchor in my concrete pad that the trailer would be chained to. i know the lock is the week link but at least it might take them a little longer than backing up wraping a chain around it and haulin buns.
thanks
   / trailer security #2
thanks
This is just what you need...:)
Custom Boots and Locks~The Guardian Wheel Lock
   / trailer security #3
something similar would be a lock/chain that runs thru the wheel holes and is attached around the axle.. It keeps the wheels from turning..
this isnt exactly what I have seen before, but the same concept..
Trailer Lock by Trailer Keeper
good luck
   / trailer security #4
PaulChristenson said:
I had that set-up for my trailer and it worked great. The only problem I had was the one day I hooked up the trailer and forgot to remove it...I was reminded very quickly that I wasn't going anywhere!
   / trailer security #5
Take a look at these Floor Anchor Systems
:D If these wont slow em down try hookin the trailer to a live power source!
   / trailer security #6
I put a chain and padlock through two wheels on one side. I also have a padlock that goes in the latch hole on the trailer hitch. They also make a lock that fits up inside where the ball goes and locks onto the lip. Plus I usually block them in with another vehicle at times. Most places that sell trailers, especially campers, sell security locks.
   / trailer security #7
Take your tires off and put it on jack stands. :D
   / trailer security #8
I use the lock type that has a ball and hoop that locks around and inside the ball socket. It's yellow and can be defeated by running a chain through the tongue as you describe. Really though, the trailer is a relatively inexpensive piece of equipment compared to your pickup or tractor.
   / trailer security
i guess i should elaborate on why i am working on this idea. sometimes i dont get a job done in one day so i leave my tractor on the trailer overnight. my yard keeps me from putting it anywhere but on the boat/rv pad. behind this pad is a 3 foot drop off so i dont have to worry about someone backing it off. at night i park in front of it so that would stop that but every once in awhile i have to leave for a couple hours unexpectantly and then im worried. the point is to slow them down long enough for the dogs to start barking and one of my neighbors to start shooting,lol. i have neighbors on both sides who love guns. when i had a boat i would chain the tires together (all 4 with one chain) and it was a pain. i think in a pinch i will chain one side together duno why i didnt think about that and i will set an anchor of some kind.
thanks guys
   / trailer security #10
Buy a cordless impact wrench. Set a block under the trailer frame. Take wheel(s) off when you leave it at night. If you have a lighter weight trailer, should only be 5 lugnuts. You can rattle them off in 2-3 minutes. Lock the wheel & impact wrench in your truck/shed/garage, etc.
Or, buy a doberman, shepherd, rotty, etc. and leave it out back.
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
23169 (A50324)
23169 (A50324)
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
