Trailer Recommendation for Kioti RX7320
   / Trailer Recommendation for Kioti RX7320 #1
WesternMN
Western Minnesota
None
I've got a Kioti RX7320 with cab and FEL. Listed weight of tractor is 6,162, FEL is 1,468# and Bucket is 428# for a total of 8,058 pounds. Wheel base is only about 84". I drive a Ram 2500 with Cummins 6.7, air bags and 5th wheel hitch (if necessary)
I won't be moving the tractor often, just for service now and then. I'm thinking a 20' bumper pull skid loader trailer with 7,000# axles and fold up ramps would be fine. I could go to gooseneck if necessary but I like the idea of a bumper pull for general use and being able to move it around with any old truck when not hauling the tractor.
Anybody with experience hauling a tractor about this size with advice on trailer recommendation?
   / Trailer Recommendation for Kioti RX7320 #2
Sounds like you have it nailed down.
Chris
   / Trailer Recommendation for Kioti RX7320 #3
Are the rear tires loaded on your tractor? I have a 20 ft PJ tandem axle 14,000 lbs trailer.It hauls my kioti DK40 with FEL, loaded rear tires & 6 ft brush hog just fine.Towing with 2016 Ram 2500 crew cab 4X4 with 6.4 Hemi engine.
My tires are not filled. Not sure how much weight that would add? 500-600#?
   / Trailer Recommendation for Kioti RX7320 #5
I am not a expert but I think your numbers 500-600 lbs would be close.
   / Trailer Recommendation for Kioti RX7320 #6
Probably in the 500-600 pound range per tire. Total will be in the 1200# range.
   / Trailer Recommendation for Kioti RX7320 #7
   / Trailer Recommendation for Kioti RX7320 #8
I would say 14k is rite on weight, but for length, by the time you add your loader and any implements it might not be long enough. My previous trailer was 22'. but only 7k, with my new tractor weighing in around 10k I went with a 14k trailer 25' long, but I also use it for moving hay around as well.
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A51039)
Marliss Industries...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2011 FREIGHTLINER CASCADIA (A50854)
2011 FREIGHTLINER...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
