Trailer Ramps
/ Trailer Ramps #1
kclark2227
Kannapolis, NC
Kubota L4701 4WD HST
I don't know if I am saying this correctly in regards to ramps for equipment trailers.
Ladder (Long) ramps vs Knee ramps (I think it's called).
Is it just personal preference or is one really better than the other?
/ Trailer Ramps #2
The knee ramps support the back for the trailer when your loading. If you don’t support the back of the trailer you could bend the frame.
/ Trailer Ramps #3
Bend the trailer and pick up the back of the truck. And roll since the tires aren't on the ground.
/ Trailer Ramps #4
if I load a car I can get away with just a ladder ramp, when I load the skid loader need the knee ramp. 1010 is correct you will bend a lighter trailer without a knee ramp. I know i did it, long story, it was bad!
/ Trailer Ramps
When I look at a trailer with either a knee ramp or a ladder ramp, both have the additional support (legs) to keep the trailer supported. See attached.
/ Trailer Ramps #6
The trailer I use must now days is a 20'lowboy rated for 10k. I use 4' ladder ramps with no support legs.
I prefer these simple ramps because;
A. I load and unload on all kinds of surface,many times unlevel. Supports can hang up on these surfaces.
B. I often haul tractors with mower attached. Mower overhang's rear because tractor isn't all the way forward on trailer when weight is balanced so hinged ramps would be in the way.
C. Ramps with supports are too heavy to lift into transport position unless they have spring assist and springs have a way of breaking at the worst times.
D. Ramps are always too short for low center things like cars and a workaround with support ramps is all but impossible. I can put trailer wheels in a low place or back up to street curb making it easy with ladders. I have a basket of 2Xs,4Xs and blocks outside cargo space between fender and front of trailer. If I load something heavy like the 9k Lb 4020 Deere,I simply throw blocks under rear of trailer and center of ramps. When I had construction equipment,I had dedicated trailers with hinged ramps. Personal preference according to purpose.
/ Trailer Ramps #7
After bending the rear axle on a trailer by loading something heavy driven on I put jacks on the back of the ones that don’t have the supports on the ramps. Definitely like the longer ramps too as the angle is much less.
Brett
/ Trailer Ramps #8
Brett
I checked out some Diamond C tilt trailers in Seguin at D&D a couple weeks ago. None of this is an issue with a tilt trailer. Making a tilt look better all the time.
TBS
/ Trailer Ramps #9
TBS
I don’t really know how that work. Does the whole bed tilt or just the back half? I’ve seen both and don’t understand the half bed tilt part
Brett
/ Trailer Ramps #10
It's not really a half tilt, 2-3 feet in the front doesn't tilt like the rest does. You can get power tilt with elec over HYD that runs off a battery or just a plugged cylinder with fluid that allows gravity/weight to tilt down or up. With a simple but strong latch.
/ Trailer Ramps
I decided to go with a Big Tex ET10 20' with the mega ramps. Once I looked at them, I liked the mega ramps better. Plus the trailer was on Clearance. 2017 Model for $1200 less than a 2018 model.
/ Trailer Ramps #13
Very nice choice. I started to mention the MRs, but didn't know how much you wanted to spend.
That is exactly the same set up I want!!
/ Trailer Ramps #14
At first it was 3 ramps that didn’t adjust much, then there was one gate lol
I have springs in the mail lmao.
Other than the fact it takes two guys to lift it, the gate is awesome, I can back stuff on the trailer of all kinds of diff widths and never have to worry about sliding off a ramp or loading everything perfectly strait.
/ Trailer Ramps
The mega ramps only cost me about $300 more. It is a much better setup than the ladder ramps. With the spring assist, they are not heavy either. This trailer should last us a long time.
/ Trailer Ramps #16
Brett
They can do either full tilt or partial tilt. Check them out. Pretty impressive.
TBS
/ Trailer Ramps #17
View attachment 558210View attachment 558211View attachment 558212
That's nice and I'm sure it works ....but, if you are going to go to that length why not just get a tilt deck trailer?
TBS
/ Trailer Ramps #18
TBS
Because I gave $1600 for this 20ft deck over. I’m not like rustyford guy, not made of money lol. Thus my name
/ Trailer Ramps #19
But have you considered how much status you are giving up for the lack of a wide brim hat and tilt trailer?:D
2011 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2011 FORD F-550...
2006 International 4200 2,000 Gallon Water Truck (A64556)
2006 International...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
Skid Steer 3 Point Plate (A65640)
Skid Steer 3 Point...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
