Trailer Plug
/ Trailer Plug #1
ColoradoBound
Westcliffe, CO
LS XR4140HC
Can I use the trailer plug on the back of my XR4140 to power a 3pt sprayer?
I am looking for a sprayer to wet down my arena and driveway when I need to do some maintenance and I'm torn between an electric version or a pto version. If I go with the electric version I don't want to have to run the cable up to my battery every time I want to use it.
/ Trailer Plug #2
That question can not be answered with out more information.
How man amps does your pump use?
How many amps is your trailer wire rated for?
How many amps are used on the trailer wire already?
/ Trailer Plug #3
Even if your plug won't handle it, you can run a new wire as a one time job. Just run a new permanent circuit with adequate wire size and it's own breaker/fuse and install the disconnect plug of your choice.
/ Trailer Plug
The sprayer I am looking at uses about 4.5 amps
This is what I was hoping someone who has an LS tractor would be able to answer for me.
/ Trailer Plug #5
I did this for a sprayer I use behind my CaseIH DX55. I found the electrical diagram in the operators manual, and it provided enough details to identify the trailer plug circuit and the amps/fuse for it. Mine had plenty, but I forget now what it was. Hopefully yours will show that info too.
/ Trailer Plug #6
Instead of a trailer plug, maybe install one of these heavier ones like they use on electric forklifts or receiver hitch winches.
That will give more than enough capacity for what you need, and allow for future heavy current requirements, if any.
/ Trailer Plug
I have so many other things to do that I would prefer not to have to run new electricals if I can keep from it.
/ Trailer Plug #8
I believe that plug is rated for 10A so you should be able to run a 4.5A sprayer pump off it. Here's the pinout for the plug. You'll need to get the female end that plugs in to the plug on back of the tractor. Most any trailer place should stock it. Even NAPA may have one. Double check your tractor pin out to be sure.
/ Trailer Plug #9
Also check your manual to see if they show how the pins are wired. There are several ways they can be wired, and my tractor was wired for ag use. The center pin was a switched accessory lead, and the bottom pin was unswitched.
/ Trailer Plug #10
Yup. These are awesome. Runs the sprayer, fuel transfer pump, baler monitor, winch, whatever. Heavy duty and cheap on Ebay.
Quick Attach Rock and Tree Hand (A65579)
Quick Attach Rock...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2022 EZ-GO ELITE...
2005 Lexus ES 330 Sedan (A64194)
2005 Lexus ES 330...
MUD MIXING FRAC TANK (A65643)
MUD MIXING FRAC...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
