Trailer options for sensitive equipment
/ Trailer options for sensitive equipment #11
I would look at a air ride kit for the trailer and a air hitch, I forgot the companies name but buddies truck has one and it handles great. search air hitch and watch there vidio's more than I would spend pulling tractors, but would be the ticket for your use.
/ Trailer options for sensitive equipment #12
thanks for all the great posts everyone, I'll be checkin' out those links.
Been shopping around at the local trailer suppliers and starting to lean toward a stock trailer with torflex, but modifying the inside with a custom sub-frame that would include its own vibration compensation. (similar to those anvil cases, but on a large scale for our AUV)..
How much does this thing weigh? Will it need to be lifted out, or can you roll it down a ramp?
You have may have already thought of this, but if it it heavy you might be well served by making a "subtrailer" that is like the cradle on the page on your link but with 10 or 12 inch tires on it, make it so that it can be winched up into the trailer. Perhaps something like this: http://n.b5z.net/i/u/10066744/i/notch/FlaredMobileBunkFeeder.jpg (but in the correct size) so that you can easily use a winch to pull the "subtrailer" onto the big trailer. You could then put your "good" suspension on that and it would only need to dampen the weight of the AUV, not of the whole rig. That would also let you move it around easily on the ground.
5th wheel or gooseneck is not an option for us due to availability of trucks, much easier for us to get access to bumper hitches than anything else.
Very logical, you can use most any vehicle (Truck, Van, SUV) with a heavy enough bumper hitch that way
Aaron Z
Aaron Z
That seems to be the way we're starting to lean, winch it in on some bigger wheels on a custom frame. Take care of the vibration and shock ourselves.
/ Trailer options for sensitive equipment #14
I have shipped SEM's before; Scanning Electron Microscopes capable of 500,000 times magnification.
They had thier own anti-vibe system, but it required Oil Free Air. So that part of the system was down. The biggest thing for us, was making sure the UPS ispower was good; it was able to maintain the vacuum on the system which is absolutely necessary. Biggest issue we had, was that we had to unplug the system from house power just minutes before going on the truck, and it had to be back on house power within 6 hours. These systems operate under extreme vacuum; if you lose that vacuum, it takes days and days to recover.
These systems went in a big rig, with air ride suspension. The paricular systems were a couple years old; we did not have original packing, and the manufacturer did not see the need to go to that effort(they helped get the system ready to ship, and were there to recieve it to get the power and vacuum pumps running).
New, these systems did come in crates with shock absorbers. But, they came in pieces, and were built over a few days, during which that important vacuum system was high priority.
I would contact a company that deals with equipment like that.
We also shipped/received microprobers accurate to sub nanmeter. They went by air and/or air ride truck.
Companies like Wentworth Labs, Cascade Microtech, FIE, Hitachi ship these sensitive systems all the time. You might contact a company like that.
I would think, a well built trailer, with air ride suspension would be a start. Second, consider air ride on the tow vehicle. 5th wheel/goosneck would be a good start.
I would also consider secondary packing of the unit itself with some shock absorber features on the crate. Think about shock indicators for the packing too. They are just little stick on indicators, that will change color if a known shock level is exceeded.
To start the project, I would also consider a National Instruments or similar portable DAQ with a few transducers. Monitor your equipment to see what is really hapening on the unit you are transporting.
You may look again at goose necks, even if it requires a different truck. A different truck may be less expensive than damage to sensitive equipment.
I would though, contact a couple companies that ship/receive sensitive equipment.
/ Trailer options for sensitive equipment #15
Seems going to an airbag system may add too much cost and complexity, whereas a custom sub-frame with rubber or coiled shock mounts may do the trick. Any experiences out there?
Really? You are talking about transporting a 4.5m un-manned submarine plus the equipment needed in the trailer/workstation and you are quibbling about the cost of an upgraded trailer suspension??
I would suggest you go for the suspension option that gives the best ride period and forget building a dual purpose sub-frame that would include its own vibration compensation. I believe THAT would be the expensive route to go.
Having the sub mounted on its own vibration compensation frame does nothing for anything carried elsewhere in the trailer either.
There's an old saying..."Don't try to reinvent the wheel".
The groundwork and development has already been done on various suspension systems...make use of that.
I fully agree. My concern is not the cost so much as the added complexity of the air-bag system, one more thing that'll need power and can fail. As I mentioned I'm not an expert in this by no stretch.
Out of the dealers I've met here in town, all but one don't even offer an air-ride package, and the one who does has never gotten one in before. How common are they on a 24' car-hauler type trailer?
Our custom sub-frame would be a completely passive system, that could find use outside of the trailer in our 20' container, as well as for manual moving around the University. Conversations with the manufacturer have lead us to this option as well, others with a vehicle like ours do a similar thing with a sub-frame utilizing coiled vibration dampeners.
This trailer would not be used for anything else.
/ Trailer options for sensitive equipment #17
1. Mainframe computers and such are routinely transported on big rigs with air-ride suspensions. This is well established technology. You could consider just hiring one of the companies that does this when you need your submersible transported. This is an inexpensive and sure-fire method.
2. If you really want a sub-frame that isolates vibration, take advantage of the special nature of your cargo. Built a water tank which fits the sub's contours, blow ballast on the sub and transport it in the water tank with a few lbs of positive buoyancy. The only reason to fit the sub's contours is to keep water weight down, if weight is not a huge concern, a rectangular tank would work. A few boat fenders will keep it from banging into the sides.
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
Spreader Attachment (A56859)
Spreader...
(INOP) 1998 FORD F-SERIES FLAT BED TRUCK (A59823)
(INOP) 1998 FORD...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
