trailer hitch for FEL
   / trailer hitch for FEL #1
accordionman
wright city, mo.
KUBOTA L3000DT, FEL.
i think it would be easy to move a trailer if you had a hitch
on the FEL. has anybody done this? i need to know how far
out to extend beyond the FEL. appreciate any help.
accordionman
william l. brown
wright city, mo
L3000DT,FEL, and other good stuff
   / trailer hitch for FEL #2
It depends on how tight of turns you want to make. The further out your pivot point, the sharper you can turn. Just keep in mind the trade off. The further out you put it, the stronger whatever extension you build must be and the more torque you're putting on your bucket.
Good luck with whatever you decide. I hope this helps. /forums/images/graemlins/smile.gif
   / trailer hitch for FEL #3
Lots of people here have done it.
Do a search and u should see many different styles.
If u have a Q-T on the FEL, it could be a seperate plate w/ 2" square tube so u can change hitches.
I built mine on a seperate plate that also has a Speeco 3 PT quick hitch so I can use the rear stuff on the front of my SSL.
   / trailer hitch for FEL #4
William, I know of an RV park that has an older Ford tractor with a FEL and the guy simply drilled a hole in the front center of the bucket and mounted a hitch ball in that hole. And that's what he uses to move travel trailers around.
   / trailer hitch for FEL #5
Local trailor store uses a fork lift. Has a 2 inch ball mounted on one of the forks.
Same fork lift can pick them up to stack them (yeah, space is tight around there) or hook on and tow them.
   / trailer hitch for FEL #6
Don't even need a ball, just curl bucket all the way down and hook the ball socket with the hook and go. Works for me!
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
LOT: (1) Shelf of Takeuchi & Donaldson Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (1) Shelf of...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
