Trailer GVWR
/ Trailer GVWR #1
Bpawb
Trailer GVWR is that the total weight limit including trailer & load ?
Or is GVWR the total amount of weight that can be placed on a trailer ?
thanks...
/ Trailer GVWR #3
The feds define it as the "value specified by the
manufacturer as the loaded weight of a single vehicle"
Here's a link.
49 CFR 571.3
You kind of have to look down the page a little.
/ Trailer GVWR #4
The GVWR is the total weight of the trailer and the load that it can carry. The plate with the GVWR data should also list the weight of the trailer.
Just subtract the weight of the trailer from the GVWR to get the maximum payload you can put on the trailer.
For example, my trailer has a GVWR of 10,000 pounds and weighs 2800 pounds, therefore, I can carry up to 7200 pounds of tractor stuff.
Good Luck,
Kevin
/ Trailer GVWR #5
G(ross)VWR as in total. Very important since my 10,000 lb GVWR trailer weighs 2500 which is a bunch.
/ Trailer GVWR #6
To add to the confusion I have a tandem bumper pull trailer that has farm tags on it, it has two 7,000lb axles and weighs 2,200 lbs so it has in my mind the ability to haul 11,800lbs the state registers farm trailers differently apparently and says it can haul over 30,000 lbs how does this make sense, actually I think the registration says 34,000lbs. /forums/images/graemlins/confused.gif
Steve
/ Trailer GVWR #7
The weight listed on the registration is only how much weight you are paying road taxes on, and does not have anything to do with the actual capacity of the trailer other than they probably always round up to the next weight class.
The "registered" weight is also sometimes used to determine what kind of license you need to rive the combination. Many trailers with 12,000 lbs axles are "registered" at 9,900 to stay within what can be driven without a class-B license.
- Rick
/ Trailer GVWR #8
Steve, I used to have a 5' x 10', single axle, tiltbed trailer, but as you said the farm registration had that 34,000 or such rating. /forums/images/graemlins/laugh.gif I asked about that, and the lady told me all farm trailers were registered that way in Texas.
/ Trailer GVWR #9
Sounds like everything really is bigger in Texas.
/ Trailer GVWR #10
Bird since you have a law enforcement background tell me with the trailer rated by the state at 34,000lbs if a trooper pulled me over for appearing overloaded does he check the registration and say OH! 34,000lbs nevermind or does he slap me upside the head and say dumby those are 7,000lb axles you can't haul that on my road and give me a big ticket.
Steve
/ Trailer GVWR #11
FWIW:
In PA. you may register a vehicle at what ever you wish provided that:
The registered weight is above the Manufactures supplied Vehicle Weight, and does not exceed the Manufacturers supplied Gross Vehicle Weight Rating.
This comes from Title 75, Pa. Vehicle Code.
Now, if you register your trailer at say 10K(to save on registration fees) when it has a GVWR of say 20K thats ok. Provided of course your trailer and load don't exceed 10K in the event you get weighed.
However, if you purchase a trailer that has a GVWR of over 10K, you need a class "A" CDL to pull it, regardless of what weight you register it at. Hope, that all makes sense?
/ Trailer GVWR #12
Steve, I was a city cop and never got involved with weight enforcement, but I think it all boils down to the fact that they just don't mess with farm equipment at all. You can do just about whatever you want to do if you have farm tags. /forums/images/graemlins/laugh.gif
/ Trailer GVWR #13
Bird as far as farm tags and farm equipment is concerned I know what you mean when I take my tractor for service I give the sheriff a call and let him know I'm on my way and then hop on my tractor and drive down IH10 about 16 miles I try to stay on the access road when possible but regretably the county ran out of money years ago and most of the way I'm on the Interstate shoulder heading west. They just smile and wave when I drive by course I do display my slow speed vehicle triangle and hazard flashers but I'd sure figure one of em would get out and ask me where you going boy.
Steve
/ Trailer GVWR #14
"In PA. you may register a vehicle at what ever you wish provided that:
The registered weight is above the Manufactures supplied Vehicle Weight, and does not exceed the Manufacturers supplied Gross Vehicle Weight Rating."
Was this a whoopsie? The WA DOL will allow me to buy tonnage and register my truck for way more than the stickered GVWR. In fact, when I bought the truck with a 6200 lb stickered GVWR the registration listed 8800 as the licensed GVWR. The next time I renewed the gal asked if I want 10,000 or 12,000 but I thought 8800 is plenty for a half ton.
If you do something to make the coppers suspicious, they will pull you over. They have corny laws that are subjective like driving too fast for conditions. Make sure the load looks good when going down the road even if you are well within your ratings just give it a look for presentation.
/ Trailer GVWR #15
Actually, as complicated as the verbage makes it sound it shakes out fairly simple:
You MUST register at a weight above what the EMPTY Vehicle weighs.(as provided by the manufacturer)
You MAY register at ANY weight as long as it is not above the MANUFACTURERS GROSS VEHICLE WEIGHT RATING.
So, if I buy a dump trailer with a GVWR of 10K, but I only use it to haul 4K, then I can register at 7K and save a few bucks.
It really isn't worth the trouble, but the option is there.
/ Trailer GVWR #16
I hate to start a whole big thing that isnt really related to the thread but just to clearify.
CDL B is for any vehicle or combination over 26000lbs provided the trailer is less than 10000lbs.
CDL A is any combination over 26000lbs with a trailer of 10000lbs or more.
This means, for example, its legal to pull a trailer with a GVWR of 12000lbs as long as the GVWR of your truck is less than 14000lbs without a CDL because you stay under the 26000lbs combined limit.
EDIT: This is for commercial vehicles only. If its operated privately, the weight limits are irrelevant.
/ Trailer GVWR #17
Again, this is FWIW;
I contacted the Pa. State Police, Department Headquarters, Bureau of Patrol, Division of Motor Carrier Enforcement. According to the Cpl. in charge the following is applicable to vehicles registered in Pa.
A Class B CDL entitles the holder to operate a single vehicle having a GVWR of 26001 or more, provided that any vehicle being towed does not have a GVWR exceeding 10,000. When I questioned him regarding the effect of GCVWR he advised it would be irrelevant. He advised that regardless of the towing vehicle registration, once you hook to any vehicle which has a GVWR exceeding 10,000 you need a Class A CDL.
Armed with this information, I went to the Pa. Dept. of Trans. web site, Driver Services Section, Pa. Vehicle Code-Title 75, Chapter 16-Driver Licensing, Section 1612, and there it was in print, as stated by the Cpl.
/ Trailer GVWR #18
</font><font color="blue" class="small">(
Armed with this information, I went to the Pa. Dept. of Trans. web site, Driver Services Section, Pa. Vehicle Code-Title 75, Chapter 16-Driver Licensing, Section 1612, and there it was in print, as stated by the Cpl. )</font>
You must have been drunk when you looked it up because section 1612 deals with driving under the influence of alcohol. /forums/images/graemlins/smile.gif
1603 is the section that defines "commerciial vehicle" as having to be over 26000lbs.
I dont want to ruin this thread. Would you like to contuue in another one?
/ Trailer GVWR #19
It is regrtable I inserted the incorrect section number. My attempt here was to obtain some information that might be of use to someone on the net. If your request to go to another thread is to initiate a debate on this matter, thanks, but no thanks.
Since it was the Corporal from the State Police who provided the initial guidance perhaps you could contact him and dedbate Pa. statute.
/ Trailer GVWR #20
Ok, no debate and I really dont care enough about it to call the State Police and try to get ahold of this guy.
Please understand that I drive for a living. Check out my occupation, my office has 18 wheels and Im absolutely certain about this.
Now we can carry on with the original thread.
2025 44in. HWG44 Hydraulic Mini Log Grapple Skid Steer Attachment (A59228)
2025 44in. HWG44...
2008 TOYOTA Camry Solara Convertible (A59231)
2008 TOYOTA Camry...
2014 Dodge Charger (A59231)
2014 Dodge Charger...
Deere 333E (A60462)
Deere 333E (A60462)
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
