trailer for my Ford 1720
   / trailer for my Ford 1720 #1
mr4shootin
Florida
Ford 1720 4wd shuttle
Found this on a used car lot.It's 6.5' x 16' and has brakes on rear axle.All it needs are new fenders and I found a local trailer parts place that has them for $40.00 each.When I weld them on I will put them a little higher as you can see the tires are nearly rubbing with the tractor loaded.It's a pretty tight fit with the bush hog but I think I got a fairly good deal on it and if the bush hog fits, any other implements I'm likely to get will fit.I found the best position I could and still fold up the ramps, then I screwed a 2x4 to the deck so I will know right where to stop.It has chains to hold ramps up,I just didn't have hooked on.
   / trailer for my Ford 1720 #3
When you get the welder out to put the new fenders on I would also make some sort of stop along the front of the trailer. Make it out of at least 2" tubing and make it about 8" high.
Chris
   / trailer for my Ford 1720 #4
Is that a 3/4 ton pick up?
I had to get the trailer weighed to get my tag.It weighs 1860 lbs. and my truck weighs 5,360 lbs.
   / trailer for my Ford 1720 #7
How much does the tractor weigh?
What's the trailer rated for?
```````````` With brakes on just the rear wheels and only a 1/2 ton you may be getting close to pushing the envelope.
   / trailer for my Ford 1720 #8
I have a 7xx16' car hauler.. it weighs 1700# and have no problem towing with my dodge half ton.. has 1-axle of rear brakes.
To the OP.. the reason i got detachable ramps was so i could park the tractor where it was safest with weight distributed properly to the toungue.. etc.. not convienient position.
I suggest you find where your weight is correct then install some chains/hooks to hold them ramps wherever they have to be to get that correct weight.
soundguy
Tractor and bush hog approx. 3500 lbs.
Trailer 7000 lbs.
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2014 RAM 4500 versa LIFT bucket truck (A52377)
2014 RAM 4500...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
