Trailer "D-Ring" Question
   / Trailer "D-Ring" Question #1
JDGREEN4ME
Veteran Member
Southeast PA
John Deere 2520, John Deere X534, GT 225, GT 275
Trailer \"D-Ring\" Question
The trailer I recently bought has four HD D- Rings mounted to the 2" pine decking. I checked underneath the trailer and the bolts run thru the decking and then pass thru another 2"'x6" piece of presure treated lumber than runs across the decking from side to side. Is this something I should be concerned about? /forums/images/graemlins/confused.gif
   / Trailer "D-Ring" Question #2
Re: Trailer \"D-Ring\" Question
"Is this something I should be concerned about?"
Be careful you don't trip over them. If the "D" rings are intended to lash down a tractor or other heavy gear I would think the bolts would run through the frame at some point.
   / Trailer "D-Ring" Question #3
At a minimum, there should be big heavy fender washers between the nuts and the backup board. You could improve it with some steel plate in lieu of the washers.
SnowRidge
   / Trailer "D-Ring" Question #4
I ran some angle iron pieces across the flooring underneath, spanning 3 or so boards, and then bolted the rings through that.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
