Trailer brakes
/ Trailer brakes #1
Tomtint
Elite Member
Boston
L3700SU
We just got a 19 F150 for a run around truck. It did not come with a trailer brake controller and I have one on order.. my question is weather electric trailer brakes will work without one ? Anyone know ?
/ Trailer brakes #4
Your new truck is probably already wired for the installation however.....that helps a lot.
Cheers,
Mike
/ Trailer brakes
The module is scheduled to arrive on Friday. Should be a relatively easy installation.. then off to the dealer to flash the computer so the truck knows it痴 there... it is ridiculous that Ford puts a hitch and plug on the truck and calls it a tow package.. but no break controller ...
/ Trailer brakes #7
What controller have you gone for.
We have 3 Tekonsha Prodigy controllers on our vehicles and have found them very reliable, electric brakes on horse float, boat and caravan, all brakes on a single axle but they will control 3 if you choose to have brakes on more than one axle.
/ Trailer brakes
I installed it today, I went with the OEM Ford unit. It plugged right in and fits in a little slot specifically made for it in the dashboard.
I'm getting it programmed to the truck on Saturday morning. It's nice to be able to adjust it on the dash and select which trailer I hook up too from the trailer tow menu.
/ Trailer brakes #9
What a coincidence - I just saw part of this movie on TV today over lunch. I had never heard of trailer brakes that operate with a completely separate handle.
/ Trailer brakes #10
I’m also surprised that the towing package didn’t include a brake controller. I initially thought you might have been mistaken. I checked Ford’s website, and I didn’t even see a separate option for a brake controller.
/ Trailer brakes
I think it's nuts. The part is only 90.00... truck came with the hitch, the 7 pin connector..the stupid dial for those who can't back up a trailer...and no brake controller... go figure...
/ Trailer brakes #12
Sometimes they actually do install "brake" controllers.
/ Trailer brakes #13
Mine came with the controller but it’s a 2013 and HD payload model, so better equipped for heavier trailers. Most pickups end up pulling landscape trailers and never go above 3 or 4K pounds. I’m surprised how many guys don’t know what mine is since they never tow a trailer with brakes.
/ Trailer brakes #14
I think they were quite common 50 years ago; I pulled a trailer house from Western Oklahoma up into Kansas on wheat harvest, and the electric brakes on the trailer were operated by a hand brake in the truck. As for the old movie, I recall watching it when it came out. We thought it was hilarious; and very apropos for the time. I recall them buying this trailer, and he then had to buy a new car to pull it with. But, we were easily entertained in those days.
/ Trailer brakes #15
For light duty trailers, you need the hitch and the wired plug for lights. You don't need brakes and a controller until the weight of the trailer is above 2000# in Ohio (it varies state to state generally dependent on the gvw from 1500# to 6000# or so.)
Trailer Brakes - AAA Digest of Motor Laws is a good start but check your actual state laws, they are often more complicated than the AAA guide.
/ Trailer brakes
All my trailers are dual axle , so all have electric brakes. This 150 won’t be pulling anything heavy, maybe the Kubota on a rare occasion. But without the controller.. the trailer would just be banging around on the hitch.
/ Trailer brakes #17
Mine are all dual axle but only braked on the front one.
We can tow up to 750kg (about 1500lbs) unbraked and over 2000kg we have to have a breakaway unit.
I also use 2 tonne rated hooks on the tow vehicle to attach the chains, I hate trying to screw in shackles where I can't see.
/ Trailer brakes #18
- A lot of people don't tow a heavy enough trailer to need brakes(under 2500lbs?)
- A lot of people tow with surge brakes and dont need a controller; boat trailers commonly use surge brakes
- Some people like controllers besides the factory supplied units.
/ Trailer brakes #19
Good choice going with the factory brake controller, it ties into the factory stability control system (which after market can't)
after going years without brakes on my trailers (mostly small utility and boat trailers) I am a firm believer that all trailers should have them
/ Trailer brakes
I got the controller installed last week...it was relatively straight forward. Just had to figure out where the screws and clips were to remove some of the interior trim pieces. Took about 45 minutes total. After that I had to get the dealer to plug it into their system and have the truck recognize the unit. They charged me 65.00 to do it. .... personally I think they could have done it as a courtesy after buying the truck from them..but it is what it is. .. I know it's done and done right. Haven't towed with it yet, maybe tomorrow...my tractor needs service and I may use it to tow the Kubota to the dealer. ..I'm curious how the 3.5 Ecoboost tows...supposed to do well but I'm accustomed to a Diesel and V10.
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A61572)
2006 Snorkel AB50J...
Generac Generator (A61572)
Generac Generator...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2016 Ford F-150...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
