Trailer brakes and how to make them work right
   / Trailer brakes and how to make them work right
I think you are right on this issue. That way the trailer is not activating the brakes when I do not want them to be working. I do have a lock out pin that I insert into the tongue for backing up, homemade and very cheap.
I still would foresee a downhill issue also. The only 2 differences I knew of,(disc vs. drum) reverse solenoid and higher pressure (disc is higher). You may want to look at adding an electro/hydraulic actuator instead. Not a cheap alternative by any means, but ........
   / Trailer brakes and how to make them work right #12
You stated the brakes are rated 6K on one axle but you probably only have 3500# axles if your trailer is rated 7200#. Sure sounds to me like the brakes are overloaded. I'd put put the brakes on the second axle so they work half as hard. I'd bet your problem pretty much goes away.
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
