Trailer brakes adjustment - dragging
   / Trailer brakes adjustment - dragging #1
Chris611
This spring I replaced all the brake backing plates on my Loadmax 14k Gooseneck. 3 of the 4 have done great, but I have one brake backing plate that continually seems to keep heating up. I have adjusted them all the same and re-did the wiring to the suspect backing plate. I replaced all of them with AL-KO backing plates (it has AL-KO axles). The last trip, when it got hot, I disconnected the electrical to that brake that gets hot to see if the would stop the heat buildup. I drove awhile and then stopped again and it was still hot. The wheel spins free when jacked up, even when hot. The only way I can get it to stop heating up is to back the adjuster off all the way. I've done some internet searches, and came across some discussions about under-adjusted brakes causing heat build up. Seems counter-intuitive. I adjust the brake until wheel won't turn and then back off about 10 clicks. Any thoughts on the under-adjusted brakes or should I just buy a new backing plate and hope that it solves the problem? I've had it apart numerous times and can't find anything binding or unusual. Need to get it fixed before I blow a $120 trailer tire because it overheats from a dragging brake...:ashamed:
Chris
   / Trailer brakes adjustment - dragging #2
I adjust by spinning till I find a slight drag then back it off 3 clicks.
That being said are you sure its not the bearings.
Chris
   / Trailer brakes adjustment - dragging #3
Chris
I don't back mine off 3 clicks, but I tighten mine the same way ,Till the wheel drags a little
Chris
I repacked the bearings this spring. I didn't see any issues with the bearings when I pulled them apart and cleaned them. The castle nut can be removed by hand.
I also don't think it's bearings becuase when I back the adjusters off all the way and disconnect the electrical, I don't get any heat breakup.
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
City of Lakeland (A51691)
City of Lakeland...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
