Forks Trailer ball on front forks
   / Trailer ball on front forks #1
cobbkevin
1957 MF 35
I'd like to be able to move trailers around the place with the front of the tractor. I have a rear drawbar (multiple holes) that has an anti-roll keeper to help align things but usualy have something else on the back instead, plus it's a little easier to manuever when you can see in front :)
I normally have a pallet frame and 42" forks on the FEL so - I want to put a ball up there. I thought about drilling one fork for a ball but the load would be off-center (probably not good idea). So I thought about a bar across both forks with a hole in the middle, maybe a channel for support and a bar back to the pallet frame to keep from sliding off the front. Has anyone seen something like this?
Kevin
   / Trailer ball on front forks #2
I used to work in a rental yard and we moved around trailers with a fork lift. We had a "shoe" that held onto the fork with a big T handled set bolt (just clamping force). The ball was attached to the shoe also. We just put the forks together in the center and used the shoe on one fork at a time. works great - very maneuverable.
   / Trailer ball on front forks #3
Drill a hole in and pop in a ball. A little off center isn't going to hurt. Sounds like the trailers are going to be empty most of the time anyway. Even a little load shouldn't hurt. A 3pt trailer lift is easy to. I think some even have a ball on the BH.
Rob
I didn't even think about sliding the forks together :eek: Ok, a side question is how hard is the steel in forks? Do they drill with any reasonable effort or do I need to burn a hole through them first?
Kevin
   / Trailer ball on front forks #5
Weld a ball to a shoe that will fit over the end of one of your forks. Then run a chain back to the loader to keep the shoe on the end of the fork. Easy to slip on and off. A little slop won't hurt you.
   / Trailer ball on front forks #6
If the trailers are loaded normally the ball weight would not be a problem for one tyne if slid to the center . But 2 things you must do is 1/ Make sure the bottom of the tyne is captive ie chained to the fork frame . otherwise it can pivot up and smash the coupling/ball and escape . 2/ Dont flame cut the hole , it will reduce the tyne tensile strength from 750mpa - to around 125mpa with the heat (nearly mild steel) . Use a magnetic drill with a Broach . Take the tyne to a metal shop and have them do it .
   / Trailer ball on front forks #7
Kevin
Very Hard! It can be drilled, but as Iron Horse said a machine shop can do it much more easily.
andy
   / Trailer ball on front forks #8
I've seen quite a number of forklifts with a hitch ball in the end of a fork, but when we were full time RVers, we stayed in at least one park where the owner had drilled a hole in the lip of the front end loader bucket and put a hitch ball on there. By having the ball back closer to the tractor, he could handle the tongue weight of just about any conventional trailer.
   / Trailer ball on front forks #10
cobbkevin -
I have been planning on the exact same thing as you, using a piece of 6 inch channel, about 42 inches long, for the cross member and welding a receiver right in the middle. I was going to use a couple of short pieces of angle iron on the under side of each fork with bolts on each end extending upward through the channel. The angle iron and the channel would "sandwich" each of the forks and you just tighten down the bolts to hold it on.
I was also planning on having a safety chain that went from the channel back to the fork frame, just in case.
Also, I plan to weld grab hooks to each end of the channel for lifting duties.
Best of luck with your project, and I'll post pics of mine when I get it done.
2012 Ford F-450 XLT (A50120)
2012 Ford F-450...
John Deere 1023E (A50120)
John Deere 1023E...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51244)
UNUSED TOPCAT...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2014 FREIGHTLINER S/A SERVICE TRUCK (A51243)
2014 FREIGHTLINER...
