Trailer air bags
   / Trailer air bags #2
If it only hits going in barn, make a smoother entry and if it hits all the time just lower the front a little and if that won't work get some lift blocks depending where your axle is to the spring
Jim
   / Trailer air bags #3
You could also lay boards down so that the trailer tires roll up on them raising the trailer as you back it in. I would not mess with the suspension. You will then have a trailer that is harder to load due it being higher plus the extra maintiance.
Chris
   / Trailer air bags #4
bones1 said:
Anyone ever hear of putting air lift bags on a trailer?I need a little extra height backing the dovetail into the barn.
Maybe try to spread a few inches of 2A modified or concrete crusher run and make a driveway that gets rid of the jump-up into the barn.
   / Trailer air bags #5
It is very do-able depending on your skill level. I've seen many airbag set ups on semi's. I even have helper airbags on the rear of my class C motorhome.
I would go to a good motorhome/camper supply and see what they have in stock and how I could make it work as helpers to the springs.
You don't want to use riser blocks because they make drive on loading harder.
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
ALLISON TRANSMISSION (A53843)
ALLISON...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2016 New Holland Roll-Belt 450 Round Baler (A52384)
2016 New Holland...
