Trailer air bags
   / Trailer air bags #2
If it only hits going in barn, make a smoother entry and if it hits all the time just lower the front a little and if that won't work get some lift blocks depending where your axle is to the spring
Jim
   / Trailer air bags #3
You could also lay boards down so that the trailer tires roll up on them raising the trailer as you back it in. I would not mess with the suspension. You will then have a trailer that is harder to load due it being higher plus the extra maintiance.
Chris
   / Trailer air bags #4
bones1 said:
Anyone ever hear of putting air lift bags on a trailer?I need a little extra height backing the dovetail into the barn.
Maybe try to spread a few inches of 2A modified or concrete crusher run and make a driveway that gets rid of the jump-up into the barn.
   / Trailer air bags #5
It is very do-able depending on your skill level. I've seen many airbag set ups on semi's. I even have helper airbags on the rear of my class C motorhome.
I would go to a good motorhome/camper supply and see what they have in stock and how I could make it work as helpers to the springs.
You don't want to use riser blocks because they make drive on loading harder.
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
10x16.5 Tire Assembly (A53472)
10x16.5 Tire...
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
