Trading Up to a 4310
   / Trading Up to a 4310 #1
PrevNuru
All, i am trading up to a 4310 ehydro from my JD 4100. I was hoping to get some tips on things to check for prior to accepting delivery. Any suggestions you all can provide will be greatly appreciated!
Nuru
4100 turbocharged
Yes i forgot my password:confused:
Yes I do need to get a password reset sent to me
but the server is not doing it yet for some reason, it has been a coupel of weeks. :mad: Can anyone assist with that too?:p
Thanks
   / Trading Up to a 4310 #2
Nuru
4100 turbocharged
Thanks
I am back, i finazlly remembered ny password!
   / Trading Up to a 4310 #3
Welcome back, Nuru!
I don't think you'd have any trouble looking over a tractor. You know what one should be like.
Good kuck on your purchase. the 43xx series machines are some of Deere's finest for 10 acres or so...
   / Trading Up to a 4310 #5
RoyJackson said:
Welcome back, Nuru!
thanks Roy and thanks for your help.
Yes this tractor only has 65 hours on it, is two years newer than mine and I am getting $11.5k for mine in trade. Mine has only 117 hours on it. So I am getting newer/bigger/less used at least in hours.
   / Trading Up to a 4310 #6
gbick said:
The 4310 is a sweetie. Greg
Thanks one of the chores is mowing as quick as possible about an acre of grass on land that has some slopes. Hey a question comes to mind. This unit has a 72" MMM, but I was wondering is the 7 Iron MMM that much better?
   / Trading Up to a 4310 #7
I m also looking to get some anti-scalping rollers to limit scalping
   / Trading Up to a 4310 #8
Don't know about mowing. My 4310/ 430 loader is primarily a snow mover on my one acre. Greg
   / Trading Up to a 4310 #9
That will be one of its primary jobs in the winter. In the spring and summer, i plan to use it for landscaping and landscaping maintenance. i am just hoping that that 72" MMM is not a scalp-a-holic in my hands.:rolleyes:
   / Trading Up to a 4310 #10
Nuru,
Although I do not have one myself, I have seen some work done by the 72" mid mount mower, and it cuts really nicely. I assume that you are mentioning the non-7 iron model. The 7 iron model is a little nicer and more heavy-duty, but it is not that much nicer than the older standard 72". These are heavy mowers, and although they cut as well as a lawn tractor in most cases, they can scalp some if the terrain is really irregular or one is cutting too short. I found it interesting back when I had a 72" rear mounted finish mower on my machine. My parents have a large, highly-finished lawn and my father was concerned at times when I mowed for him that I might do a bad job, or the tractor I have (3720--same size as 4310) would scalp, etc. due to the machine weight and tires. Surprisingly to him these big machines tread as lightly as a lawn tractor and actually cut BETTER than most. He had at that time a little 335 JD GT and the 3720 would easily do a better job on his lawn when I mowed it. I think your concerns are valid, but I would say the work these machines do with these heavy duty decks is quite impressive.
John M
Komatsu WA3801-7 (A50120)
Komatsu WA3801-7...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
Truck Tool Box (A50774)
Truck Tool Box...
Engine Hoist (A50121)
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
