Mowing Trade mower deck
   / Trade mower deck #21
C'mon guys - I agree with LBrown that the trailer is small, but one of the advantages of a small trailer is that the trailer does not weigh much.
There is no BH of FEL, just the tractor and deck. There is a 1900# static load to spare so the trailer is not even close to being loaded. It is routinely used to haul large equipment buckets and grapples that weigh twice the tractor without any problems with the DOT.
However:
"1900# static load to spare"?
If this means that you've got capacity to add another 1900lbs I think not.
If this means your tow package weighs 1900lbs, I think not.
Do the math:
<snip>It is hung with a 3500 pound axle and the frame is more than heavy enough.<snip>
Trailer - 500lbs (SWAG)
Mower - 250lbs (spec)
BX2230 - 1300lbs (SWAG)
Fuel, and hopefully chains - 100lbs (WAG)
Total - about 2250 lbs.
3500-2250 = 1250, not 1900, so you better not try to put another tractor and mower on :).
"haul large equipment buckets and grapples that weigh twice the tractor"
3500-(2600+500) = 400 still not overloaded
So it seems sufficient for the tractor and mower combo, could even add a FEL.
Of course I pack my B7610, which weighs about the same, on a trailer with a 12,000lb GVWR.
   / Trade mower deck #22
I have a 54" deck on my BX2200 with ~140 hours on it that I would be willing to trade out for your 60" deck. I assume that the deck attachment points are the same for the two.
Send me a PM if you still have the deck and are interested. I live in middle TN.
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
S/N: 1240824 (A55853)
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
