Tractors with Perkins Diesel engines
   / Tractors with Perkins Diesel engines #21
One problem with smaller Japanese engines are parts, many engine models, often a lot of revisions and changes for no obvious reasons and quite small productions numbers. And some of them must be throw away as they are not easily rebuilt or even has the possibility.
I'd be looking eventually for something around 50hp.
So MF don't use perkins in and around the 50hp range any more?
When did Perkins engines stop being so good?
   / Tractors with Perkins Diesel engines #23
They haven't stopped, as all major manufacturers some series are better than others, some series are better in the low hp range and not so good when every possible kw of power is squished out of the design. The quest is Perkins good engines is in the same category as how long is a rope. It depends, see people talk highly on Shibaura, lot of those was piece of junk in the eighties, the heads cracked, a lot of engines died at ca 4000h, one of the reason was that Shibaura tryed to compete in the 40 to 60hk tractor marked without designing a more heavy duty engine design. So all makes has those bad designs.
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
JRB 54" QUICK ATTACH HANG ON WHEEL LOADER FORKS (A52709)
JRB 54" QUICK...
LOT: (40 approx. ) Chain Link Fence Panels (A59076)
LOT: (40 approx. )...
