Tractors rated hydraulic flows
   / Tractors rated hydraulic flows #1
Stomper
Saskatchewan, Canada
2017 Kubota L2501
My tractor's (Kubota L2501) hydraulic system puts out 5 gpm at 2200 psi. I have been researching and found a hydraulic motor for a project I am building. The performance data for the motor says that 5 pgm flow will give me the 60 rpm that I am wanting. My question is, at what engine rpm are tractor hydraulics rated. In other words, to get the 5gpm flow what rpm would the engine be rinning. I want the motor to run at 60 rpm when the tractor engine is at or just above idle not at or near max rpm. How do I figure this into the selection of the motor.
The motor that I found is 15.4 cu.in. motor. How do I know if this motor is sized right or if I need a smaller or bigger flow motor to get the rpm I want at or near idle.
   / Tractors rated hydraulic flows #2
the stated flow will be at either rated rpm or max rpm, in your case the only speed they give is 2200rpm. At idle your engine is approx 1100rpm. The system flow will be less than 50% due to lower pump efficiency at the lower speed, but the exact amount will depend on several things including pump wear, system pressure and oil temp (ie actual viscosity). I'd figure on approx 45% of rated flow. So 5.5gpm x 45% = 2.48gpm
On the motor side you also need to factor in some inefficiency if you are trying to get 60rpm on the nose. You didn't say what kind of a motor so I'll use 93% for a gear motor. 2.48gpm x 93% = 2.30gpm flow available.
motor size = (2.3 gal/min x 231 cubic in/gal) / 60rpm = 8.86 cu in/rev. Depending how tight you need to regulate the speed you may need a flow control. and obviously if you rev the engine it will roughly double the speed. Also, at idle this motor would put out approx 2.9hp.
ISZ
   / Tractors rated hydraulic flows #3
Rated flow in a brochure or manual is at the pump, you won't get that out of the remotes, and "sometimes" some of that flow is used for the power steering too...
Some tractors do have two pumps, with one for the power steering and the other for the rest of the tractor.
So you have to be carful about what you will REALLY get out of a tractors hydraulic system.
BTW, the GPM rating, is at max RPM...
SR
   / Tractors rated hydraulic flows #4
How about a bigger, PTO driven pump that can make the flow at the engine RPM you need?
Everyone seems to be saying the same thing- it either won’t work or is marginal at best.
   / Tractors rated hydraulic flows #5
pto pumps are great, but then you have to have the hydraulic tank ect. to go with it...
SR
   / Tractors rated hydraulic flows #6
SR
Yep, depending on what OP is doing he could tie into the existing case. But the PTO option is definitely more involved.
If it’s for a auger or something it would be easier to get a motor. But if he must use that size the PTO could work.
   / Tractors rated hydraulic flows #7
The only way to know what your tractor is putting out is to measure it with a flow meter.
   / Tractors rated hydraulic flows #9
SR
According to the info I found there is a separate power steering pump, so no flow sharing. Brian
   / Tractors rated hydraulic flows #10
Most manufacturers use two pumps now. I haven't seen one that doesn't though it's possible someone still uses a single pump. I think that's simpler and possibly safer than diverting flow to the steering.
Some manufacturers add the power steering flow to the main flow and use that number in their litterature even though there's no way to combine the two other than on paper.
2017 Ford Explorer AWD SUV (A42744)
2017 Ford Explorer...
2010 TEXMEX  UTILITY TRAILER (A45333)
2010 TEXMEX...
YANMAR SV08-1D (A45333)
YANMAR SV08-1D...
2013 Ford F-150 Ext. Cab Pickup Truck (A42744)
2013 Ford F-150...
2011 LONE STAR TRAILER GOOSENECK (A45046)
2011 LONE STAR...
New/Unused 12ft x 7.4ft x 8.2ft Container (A44391)
New/Unused 12ft x...
