Tractors for Dummy's
   / Tractors for Dummy's #1
Makato
Twin Mtn. NH
Tractors for Dummy\'s
I started out in the equipment forum but after several different recommendations, I looked into PT. Spent the last week reading and checking out the video's and pictures thanks to MR, Pajoube, JJ and many others.
The situation is I'm not a mechanic. I'm just a guy, who does stuff and does it outside. Some of the threads are a little intimidating since I've not owned a tractor before but then the support group is so outstanding and the product appears to be outstanding so I figure I need to find a way to work this out.
Here's my scenario.
I have a house I bought 4 years ago in Twin Mtn, NH (moving from Texas as soon as my house sells). My sons off to the USCG Academy and I'm ready to move. My property in NH is 85 acres of solid woods surounded by National Forest (big hunter), pine in the lower section 6 acres and hardwood up the mountain. My drive is aprox. 1500' of crush pack and is a continuous incline to the house with a few twists. The drive cost the original owner 30k to build so its important to maintain. An arial photo looks like a bomb was dropped in the woods to build the house. Hopefully this creates a visual, I'll try to scan a picture next go around.
I've had someone plow in the winter and I go back and forth as much as possible to keep it in order but I always rent some kind of cutter which sucks and takes days.
Now to the questions. I have searched so much till I'm brain dead for the right equipment to maintain long term. I need to be able to keep the sides of the drive cut down, the the run-off ditches cleared, the side hills around the house cut down and I want to be able to begin clearing the undergrowth around the house in the woods to open it up.
Snow removal is huge, not much stacking room on the sides of the drive or edges because of the woods and drainage ditches. Incline of the drive is my biggest concern.
At first I contemplated a SCUT or a CUT but since I don't have allot of open land to mow, I'm not sure if its a good investment.
Then I though about plowing with my truck and going the 2 wheel tractor route like (BCS) because it has so many attachments. One thing to note, lots of rock hidden in the woods under the growth and leaves. The thought is the best equipment right for the job which sounds like the PT with all the attachments available. PT425 appears to be the ticket. Long post but I thought the detail was important. I hope you guys have patients.
Thanks......Makato
   / Tractors for Dummy's #2
Re: Tractors for Dummy\'s
Welcome aboard.
First, I think the 425 probably will do your jobs, with the right attachments. Given the size of the place, however, and the length of the driveway, more power and weight is likely to make things a bit easier. (One thing I'm sure you have noticed is that we are good at spending other people's money. )
Since you mentioned the word "mountain", an 1845 is worth a look if you can swing it.
425 or bigger, or another brand machine, I definitely recommend 4 wheel drive. A 2 wheel drive tractor can get a lot mor exciting than you may want. (They're great for work on the level, and traditional farm chores, which isn't what you're looking for.) With the limits on the sides of your driveway, you may want to consider a blower. I haven't used one, and for the few deep snows we've had, the blade and some bucket work have gotten our places clear. I'm sure others will chime in that all of the PTs work snow well. Some people prefer using just the bucket.
I hope you can get to drive a few different models and experiment with a mini-hoe, 4 n 1 bucket, etc. before making up your mind. As questions occur to you, fire away.
Thanks for the reply, I've seen you on the threads many times. From all the input I've seen, it sounds like the 425 with bars gets great traction. I haven't seen anything about the ability to use chains but I'm sure that would help more. I like this tractor and I had thought about using the plow and the thrower if it is worth the effort. Because the bucket can lift the snow, I should be able to keep it stacked instead of just pushing it like with a truck plow. I'm also thinking it may be best to stay out of the diesel catagory given my limited experience. Your right, with all the available attachments, this unit looks like it could do me justice. I see there are some guys in TX. Hopefully I can check one out.
   / Tractors for Dummy's #4
Welcome, your questions are right on track with what I went through prior to buying. I also am not a mechanic but after looking at what made up the 425 I figured the PowerTrac group would be able to help when needed. In truth my decision was made when I found that all the 425 parts were available from local dealers for the most part. That was very comforting and after almost 2 years I have only had one mechanical requiring parts. Now I must also say that I probably put my 425 in more rugged work outs than most, so having only one break down is very good.
I think this unit will work out very well for you. I would make my attachment list of essentials to the wish list. Then after you have worked the land for a year and also established your project list you can add attachments as needed. Work the unit without chains (I don't think you will need them) and buy only if needed.
We will be with you every step of the way both in spending your money and offering advise.
Good luck and keep us informed.
PJ
   / Tractors for Dummy's #5
I was hoping Tractors for Dummy's was a new video set one of you guys had made. Now THAT would be sweet!
First video: Proper attachment and use of a boxblade. See Kioti John in live action!
   / Tractors for Dummy's #6
Hello and welcome!
I am a very new PT owner myself but I thought I would at least give you the advice I can. /forums/images/graemlins/smile.gif
If you haven't seen it already pajoube has compiled a good list of forum members by state. Here's a link: PT Owners by State
Also, you can contact Scott from Power-Trac and he'll also try to find owners in your area. He was very helpful and good to work with. You may want to have him find owners near your current house, so you can test drive it and also near your new home, so you can call them and get their opinions on land which may be similiar to yours.
As far as being a little intimidated by tractor ownership goes, I wouldn't worry too much at all. This is the first machine I've ever had with hydraulics but it is all put together really simply. You may want to check out if there will be a Robins dealer near your new place that can take care of any engine issues that could arise Robins Dealers by State.
Terry, the service guy from Power-Trac, always seems extremely eager to help with questions on service and you have this forum to help "talk" you through issues. If you'd still feel more comfortable with someone being nearby to help check for other places that service tractors or work on other hydraulic equipmment. I am sure any worthwhile shop around would feel comfortable working on one of these machines.
   / Tractors for Dummy's #7
first off welcome, now the use of chains.i did it both ways,with and without.bar tires don't do as well with chains but turf tires do better with chains because of the flat tread.and nothing will have the traction you have with chains,nothing!!!.no crabing going up hill,or side ways.plus on ice they flat do it!if you plan to mow with it get the turf tires and two sets of chains and chain tightners for the grunt work /forums/images/graemlins/smile.gif
   / Tractors for Dummy's #8
Welcome. I've done lots of snowplowing over the years. I used to live in a similar situation as you will be: wooded acerage in snow country with a 1/4 mile driveway. I had a 40hp Kubota with a snowblower and a blade on my pickup. Snowblowing will work well where your drive is lined with trees but it won't get down to the road surface like a blade or bucket and the snow will pack and by spring thaw you could have a mess. I would always snowblow the drive and then go back and plow the remainder but in a really bad winter I still had to have the neighbor bring down his D4 and knock down the banks. I now live in a location with less snow and a shorter drive and have a PT 425. I use the large material bucket to clear my drive and the parking lot of our business. It works well as long as you have a place to pile the snow. I would think you would be ok with a 425 with a snowblower and a blade or bucket but I would opt for a larger machine if you can afford it. BTW I've never needed chains (knock on wood).
Thanks for the welcome to you and everyone else. I try to explain the camaraderie that goes on this site and she doesn't quite get it. Anyway, thanks for the recommendation. I probably need the bar tires also because I plan on allot of work in the woods. It can get somewhat soft in the pine area because its at the bottom of the property where all the run-off is.
Any good recommendations on where to find quality chains to fit the tires would be appreciated.
   / Tractors for Dummy's #10
Welcome to TBN! /forums/images/graemlins/wink.gif
Sounds like a really nice place you have there. The PT425 is great machine.
If you are considering making trails through the woods and such, you may want to consider the 48" brush hog. Ours works great for creating trails in a hurry. The 4 wheel drive, articulation and oscillation of the unit make it outstanding in the woods. We have turf tires on ours and traction is never a problem. However, punctures from large thorns and debris do happen. I think the bar tires may have a heavier ply. The turfs appear to be only 2 ply. ANYONE ELSE WANT TO CONFIRM THIS? /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
Chains are available in our tire size, however, I'd do like suggested earlier and try it without, first. You'd be surprised what it will do.
Our snow blade works great and will pile snow 6' high. I don't know if anyone on the board has the blower for the PT400 series.
The BCS units look really nice and you are correct about the number of attachments. I've heard nothing but praise for them by their owners. However, the FEL and quick attach on the PT425 is what sold me. Everything out front where you can see it. Exremely easy impliment changes. Very simple design and easy to work on. The hardest part is the engine compartment because they have everything in such a small place. That's the price you pay for a compact tractor. If they made it all open and airy in there, the tractor would be wider and not so compact. /forums/images/graemlins/laugh.gif It is a tight fit to get to some of the hoses and such in the engine compartment if you need to.
I'd say if you have basic knowledge of hand tools, combustion engines on the lawnmower scale and a little common sense, you should be fine working on this machine yourself.
As for the incline of the drive, you need to actually measure it. That's the only way to be sure what the steepest sections are. If if is very steep, you may only be able to plow downhill, mow downhill, etc... in which case, a different model may be needed.
Looking forward to hearing about your search process. /forums/images/graemlins/smile.gif
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
Chain Link Fence (A51573)
Chain Link Fence...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
