Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #25,531
Thank you Thomas & Backroad.
I got a couple backup brushes, but I think I will need a new bucket.
   / Tractors and wood! Show your pics #25,532
Since it came out so beautifully, I'm sure you want it to last a long time!
A lot of epoxies, even those made for boat building, are not very UV stable and must be coated in something to protect from UV. Even those labeled "UV stable" usually hold up better if coated, versus not. Might be worth checking on that.
The usual coating for protection would be spar varnish, which has a high phenolic resin content to block UV. Lots of guys glass and epoxy the floors of their wood boats, and learn the hard way that even the "UV stable" epoxies break down after a some time under full sun, without a few coats of spar varnish to protect them.
The product group I usually use is West System epoxy, and the resin is UV stable, but most of their hardeners are not. They make a special hardener for this application (#207), but even then most find something like Epifanes spar varnish over the top gives better life.
And just so you know I'm coming from having been there, here's my own little epoxy on wood project, held together with plenty of that West System #207 and protected by 16 coats of Epifanes. It ain't perfect, but about as good as one can expect for something that gets dunked in a lake and raced hard every weekend for 70 years. Varnish is of those "ounce of prevention" scenarios...
   / Tractors and wood! Show your pics #25,533
View attachment 4146046 View attachment 4146047
Good food for thought. The Total Boat has great reviews on its resistance to UV discoloration. This bench does face North and has a roof over it, in the woods, but I hear ya and will do a bit more research. This is the "bus stop" it lives in.
   / Tractors and wood! Show your pics #25,534
Oh geez... with that sort of shade, you're probably fine!
It's really cool you built that. Bus stop shelters like that used to be common around here when I was a kid, but much less so now, it seems everyone drives their kids to the bus stop now. It's nice to think that shelter you built may be there and used and maintained by others, many years after we are all gone.
2022 PETERBILT 579 TANDEM AXLE SLEEPER (A54607)
2022 PETERBILT 579...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
ASSET DESCRIPTIONS & CONDITION (A54313)
ASSET DESCRIPTIONS...
2015 KENWORTH T680 SLEEPER (A54607)
2015 KENWORTH T680...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
