WinterDeere
Super Member
- Joined
- Sep 6, 2011
- Messages
- 6,268
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
My splitter is the one machine that sits outside. I purchased a cover for it from Amazon, actually quite cheap. The covers last about 5-6 years, given my storage location isn't full-sun, and keep the machine totally clean and free of rust. You do need to watch out for wasps or hornets when you remove the cover in summer, but I've honestly had very few problems with that.Storing a splitter takes up space, don't want another engine to think about and I really don't have to split that much. I don't burn wood and everything I split is just saved for friends and family to use.
In addition to the speed problem, they're putting a lot of run hours on your very expensive tractor, in lieu of a $400 gasoline engine. Never made sense, to me.I briefly considered a three-point splitter, but after watching a few videos and looking at my specs, it looks like it would be exceedingly slow on my JD2520 due to hydraulic flow rate.
3 summers for most oak under most conditions. White oak takes longer to dry than red.If your Oak isn't burning well, are you sure it is properly dried? Oak seems to be the one wood I cannot get into the desired 15-20% moisture content range with just one summer's worth of drying.
Testing MC% of oak is never easy, because it's honestly damn hard to get good probe penetration. But if you try it, make sure you test it near room temperature, at 3 different locations along the length of a freshly-split face. Repeat x3 pieces from various locations in the stack (9 total test points), and then average the data.
Too many test on the outside of a piece of wood, rather than a freshly-split face. That just tells you the outside of the wood is dry (duh), but there can still be a lot of water locked up inside.
Depends on conditions. Most of the oak I burn is dried for 4 summers after splitting. It's under a roof these days, but I used to store on pallets and only cover in August of the year I'd be finally using it.it is true that you guys summer are longer but ourself up north we need 2 summer minimum...although 4 summers stored in the elements is too long.
Wood tends to rot faster in log form than split, in my yard.
