Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,031
NOTE: The author in NO WAY endorses operating tractors with ROPS in lowered position, even when not actually ON the tractor. You might hit your head on the folded ROPS.
There's a good position for that particular ROPS, which keeps it above head height, but still low enough to fit under a standard garage door and most errant tree branches. It's one click up from where you have yours now.
   / Tractors and wood! Show your pics #24,032
Yup, but problem for me is it still catches on tree branches in the yard. Yup, I do own a saw, but nope, I don't want to trim them up any higher.
   / Tractors and wood! Show your pics #24,033
idk looks to me like it's helping guard the PTO zone
or conversely, making it so someone keeping an otherwise safe distance may bonk their head and fall down onto the pto, idk
   / Tractors and wood! Show your pics #24,034
She rocks quite a bit when running a big branch through it, all that torque might make her flip...
   / Tractors and wood! Show your pics #24,035
When I split wood by myself, I like to split right into myself unloading trailer. It's just so easy to let the splitter push the splits right off its end into it.
This morning my wife wanted to get the splits into drying boxes so that's what we did,
Anyway, with the tractor idling, the splits come back to you, and you can easily stack the wood wherever you want,
Now when I'm alone splitting wood, I have an easy place to put it.
SR
   / Tractors and wood! Show your pics #24,036
Most wood splitters are backwards! The wedge should always be on the end of the beam. This allows way less handling and the firewood can drop to a belt conveyor or into a low enough trailer or truck.
Good photos Rob!
   / Tractors and wood! Show your pics #24,037
Good photos Rob!
The trouble with that theory is it only works in your favor when you're splitting stuff small enough to be once and done. But when splitting large rounds that have to be split 8 - 20 ways, it's actually much easier to have it on the ram and keep the log halves, quarters, etc. right on the beam.
A log catcher is key though... I don't know why all log splitters don't just come with a log catcher.
<-- splits 10 - 14 full cords per year
   / Tractors and wood! Show your pics #24,038
Either way, a logg catcher/table is priceless! I'm hoping to build one for my splitter this winter.
   / Tractors and wood! Show your pics #24,039
I love talking log splitters, since I've spent so many damn hours standing over one or another, the last 15 years. Whether you're buying or building, speed is everything. I will never understand these guys who buy these stupid-slow 35 ton splitters, with cycle times long enough to take a smoke break between splits, when you'd have to hunt long and hard to find any stackable round that won't succumb to less than 20 tons.
The best store-bought splitter on earth, IMO, is a 35 ton unit that's been user-downgraded to a 4" (20-ton) cylinder. You get the big pump (18-22 gpm), and the larger motor required to drive it, and all the up-sized lines and reservoir with the 35-ton units. But by downgrading it to a 4" cylinder, you can halve your cycle times, and have something that's actually usable by someone as impatient as me.
   / Tractors and wood! Show your pics #24,040
That's not exactly true, it depends on the splitters design, I split some big wood,
With mine, I can reach over the 4-way and pull what needs split again over backwards right back on the beam and push it through again.
IF there's two pieces, one I pull over, the other can stay on top of the 4-way or it stays on the table grate to be slid back.
SR
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
