Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #23,951
Finished your crane...and still found time to paint your front weights Mr. Gordon!
Bet your shadow has to run just to keep up with you!
Somehow you got the wrong impression. If my shadow ran at all it would be out of sight up ahead.
gg
   / Tractors and wood! Show your pics #23,952
The theory behind this particular action is to promote new and perhaps more varied growth. Chances are some lower growth species will happen but the plan is for a mixed species and age to emerge over the coming decades.
Preferably not so much hemlock. :cool: While it's a nice tree to look at and certainly has it's place, value is limited for somebody who has a woodlot for growing timber.
   / Tractors and wood! Show your pics #23,953
That’s true and the hope is for mixed hardwoods regen
   / Tractors and wood! Show your pics #23,955
My wood and latest tractor picture
Got a call 📞 yesterday that part’s are in ( only took six days 👍🏻)
Need to get the wood to the shed, the rains are coming!
   / Tractors and wood! Show your pics #23,956
I gave my crane a field test yesterday. I picked up wood in 3 spots. Each spot had bigger wood, getting a feel for things as I went. I knew that the boom hinge post needed to be plumb. If it is at an angle the boom will seek the lowest point and rotating it from there is like pushing up hill. When released it will rotate back down on it's own. I use this to my advantage when traveling. By tilting the post back the boom will drop to the back and follow behind the tractor. I use the tractor TnT hydraulics to plumb the post. I was surprised how quickly the cylinders drifted and I needed to continually readjust to plumb. I see some check valves in my future. Other than that there were no nasty surprises. I picked up a strong half cord.
I made a video. Half hour. It has two parts. The first spot, just starting out, with small wood and the third spot after a little practice. I work slow and try to keep my mind on what I am doing. Even so, I push the hydraulic lever to hard relative to the weight involved once in a while.
I hope to use this set up in a section that is isolated above a vertical rock ledge. The narrow trail up to it slabs the ledge and make a sharp hair-pin turn at the top. I can't skid any thing longer than 8 or 10 feet down thru there. Plus it is almost a mile away from my wood pile. But, there is a ton of beech with BBD up there. Perfect firewood.
gg
   / Tractors and wood! Show your pics #23,957
   / Tractors and wood! Show your pics #23,959
gg
Is it check valves needed or is it the cylinder packing bypassing?
UNUSED LANDHERO IH-IW21 1" AIR IMPACT WRENCH (A51248)
UNUSED LANDHERO...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
(APPROX 50) 2" X 2" X 98" TUBING (A51247)
(APPROX 50) 2" X...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
