Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #22,192
   / Tractors and wood! Show your pics #22,193
Looks like plenty of wood for your neck of the woods (y) My daughter and family live out that way in Portland.
gg
How does your daughter like Portland Gordon? :)
   / Tractors and wood! Show your pics #22,194
One beech and one elm filled the trailer today!
   / Tractors and wood! Show your pics #22,195
Apparently they like it? They moved there when my SIL went back to school and have been there 18 years. She left here in '91 and went to Marblemount, WA. I have no idea how she ended up a city girl.
gg
   / Tractors and wood! Show your pics #22,196
gg
We just use wood for heat, usually about 7+ cords a year!
We try to stay away from Portland these days, to many bad things happening there!😢☮️✌🏻IMG_5510.jpeg
   / Tractors and wood! Show your pics #22,197
We grow Christmas trees in your neighborhood on 30 acres... the last few years have been rough with the heat, minimal rain and fires...
Hoping for the best but farming is what it is...
Friends moved their business from SF Bay Area to Portland 15 years ago and says it turned out to be a huge blunder...
At least you guys can still heat with wood...
   / Tractors and wood! Show your pics #22,198
The good thing is in the summer, we are almost always 10 degrees less than Portland.
We are @ 2000’ elevation on 5 acres with plenty of trees 🌲
   / Tractors and wood! Show your pics #22,199
After all that July rain some of the higher places are dry enough to work in. This weekend I started a new stud wood pile.
I set my camera out while I worked on this up-rooted blow down lying across a tractor road. It is not a big tree by any means but it is big enough to make three stud wood saw logs. Took these photos off the video.
I wish I had thought to put a chunk of wood under the butt to keep it up off the ground before I cut it off of the up-rooted stump. Usually a good idea. I had to make a couple more cuts to remove the butt rot with the tree on the ground. Can be hard on the chain. It's been so long since I ran the saw it seemed a little out of tune.
Winched in the two bottom logs like this.
The top log I winched in small end first using the first two logs as an anchor and their sliders as a snatch block. If your not careful this is a good way to put a curlicue kink in your cable. It happens if there is a lot of tension in the cable going around the sharp bend. Just like when a Christmas ribbon is drawn over a scissors blade under your thumb to make a fancy curlicue bow. But with a light log and a movable anchor that will not happen.
My camera timed out (memory full) just as I started to winch in. But the log came in as planned and completed the three log hitch.
Here's the 15 minute video
gg
Thanks for the curlicuing lesson Gordon! :LOL:
   / Tractors and wood! Show your pics #22,200
SCAN FOR HAULING AND FINANCING INFORMATION (A51246)
SCAN FOR HAULING...
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
