Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #16,751
Clearing land, reclaiming pasture...
Yesterday, I pulled over a 12 inch Maple with the tractor because I don't want to leave any stumps in the field.
Couldn't push it over, so put the chain about 25 feet up the tree to leverage pulling it over. (Yes Ma, I used the draw bar, 3 chains and a heavy tow strap to be clear of the tree when it fell.)
It took the MX6000 with loaded tires and 800# box blade a dozen tugs to loosen the roots and finally get it to topple.
The root mass ended up about 5 feet in diameter for that little tree.
Said that as a simple comparison to your huge trees toppled by the storm Mr. Oldtimer.
Your root mass is huge, just a guess, but easily a couple thousand pounds, and your trunks at the base looks nearly 4 feet in diameter.
It must have been a powerful wind to have taken that set of trees down, and that was without having leaves on the trees to act as a sail.
Hope you didn't lose your home roof in that storm!!!
What techniue did you use to get a chain 25 feet up the tree?
I typically use a ladder to get some leverage for leaners. and attached a tree saver strap, then cables, but I can only get up about 16 feet. Thank you
   / Tractors and wood! Show your pics #16,753
Yes and besides the large tree sections moving around violently and unpredictably the saw tends to get thrown back towards your face when the root end goes up.
gg
Yeah, that is not good
   / Tractors and wood! Show your pics #16,754
I don't do the chain up in the tree thing but I do have ladders up to 40 feet!
   / Tractors and wood! Show your pics #16,756
I could use a 40 foot ladder, but would then need to find somebody to climb up it. :D
   / Tractors and wood! Show your pics #16,757
I used to be a contractor, I haven't used that ladder in years, but I keep it around "just in case". Sure as can be if I ever sold it or something I would need it the next day!!
   / Tractors and wood! Show your pics #16,758
^^^ Ain't that the truth.
   / Tractors and wood! Show your pics #16,759
Worked on sawmill slabs today for garage heat, they say winter's coming but not sure........
L34OO and sawmill slabs - YouTube
   / Tractors and wood! Show your pics #16,760
Looks like the chain on the rear tire needs to be tightened.
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2016 Ford Explorer SUV (A51694)
2016 Ford Explorer...
Electric Mobility Scooter (A51694)
Electric Mobility...
2022 RHINO X1808 LOT IDENTIFIER 43 (A53084)
2022 RHINO X1808...
ECHO PB-580 H/T GAS BACKPACK BLOWER (A51248)
ECHO PB-580 H/T...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
