Mikejeakins
As Gordon already mentioned, it's a Frost Bite. The Igland GR 20 is very similar. A have another brand: the Sundown GR40.
The style is known as a Forestry Grapple. It works great for long logs, some large rocks, and fairly well for cleaning up brush and limbs. It's a three point grab (two under, one over the log). This works quite well for long logs, since you still get three points of contact in a good geometry for gripping, even with odd shaped logs. The narrow profile makes it much easier to maneuver in tight spots in the woods (at least when you are not carrying a log). It's light weight, so you don't lose much lifting capacity. My Sundown GR 40 weighs about the same as the 66" bucket it replaces.
I had tried a friend's grapple that was the more common style: His was a "single lid", and it would only grab very uniform logs well. If there were bends or significant taper in the log, it would pinch one end top and bottom, but the other end was loose, allowing that end to swing around a bit. (You could fix that by going to a dual lid set-up, which is kind of like having two independent "thumbs" on top, but that tends to add expense and weight). My friends grapple was also much heaver than the Forestry Grapple. His grapple will run rings around mine for other uses, but for work with long logs in the woods, a forestry grapple is hard to beat.
The Sundown GR 40 cost me about $1500 several years ago, including the skid steer quick attach plate. That price does not include the hydraulics on the tractor to run it. I already had rear hydraulic remotes, so I ran hoses up from the rear to the loader frame with quick disconnects on each end to run the grapple. This means using one of the levers on my right fender to open and close the grapple. If I had it to do over again, I'd consider springing for some kind of 3rd function mounted on my loader joystick. I don't have the bolt-on extensions that Gordon has. I've considered them, but my tractor is small and doesn't lift a whole lot, so I'm not sure if I'd gain much from them.
The Gr 40 is well built and seems to be holding up well, however, I'll admit that the Frost Bite is better constructed. I'll probably never wear mine out, especially since it's designed for a larger tractor than mine, and I'm not using it commercially. However, had I known about the Frost Bite when I bought this, I would have seriously considered it, especially if the price was at least close to the Sundown unit.
Tractor in Logging Mode
Storm Damage Clean Up
1400# American Elm Sawlog
Is that a Uni-forest winch on the back?
