John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,575
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I agree, what a back saver, should have got one years ago. Had to look up what a pulp hook is. I have some hay hooks in the barn,looks like they would do the same thing?
Some pulp hooks have a specially shaped tip - it's almost like a little barb on the end. It makes it stick in the wood better, but you can still release it with a slight flick. I find mine works well for reaching out a bit longer - similar to what I'd use my LogRite Hookaroon for, but not as much reach. The pulp hook also works OK for lifting, but is not as "positive" a lift as some other tools. While the bale hook can work to slide logs toward you, I found the shape was just enough different that it was not all that convenient to use.
My favorite tool for loading firewood rounds into the splitter or picking up one end of a log to reposition it is a set of Husqvarna 8" Timber tongs (sometimes referred to as Lifting Tongs). It saves a LOT of bending: just push them down onto the log, and the jaws spread. Lift, and the jaws dig in, lifting the log. The jaw opens to 8", but I regularly pick up 12" diameter logs with it, sometimes even larger (smooth barked hardwoods like Beech are tough at the larger diameters unless you keep the tips sharp - I only have to sharpen mine about once every two years or more).
They also make a 12" version, but I found them too cumbersome to carry around in the woods with me. Plus, if I get much above the 12" diameter hardwood logs I can lift with the 8" tongs, I'm not likely to be lifting them one-handed anyway.
A tip: if you are searching on Amazon, look at both the 20CM tongs and the 8" tongs. They are identical, as far as I can tell, but the price can differ significantly.
A handy accessory for the 8" tongs is the Husqvarna tool holster. The 8" tongs fit in there perfectly: loose enough that removal is easy, tight enough that they don't fall out. I keep one holster on the belt of my Chainsaw chaps, and another on a belt that holds a variety of tools for working in the woods (wedge pouch, axe scabbard, small first aid pouch, chainsaw multi-tool).
