Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,011
I cut a load of big rounds. Loading them would have been about a hundred times easier if I still had a grapple.
Sooooooo, what would possess you to get rid of a grapple? Friendly question, just curious. :D
   / Tractors and wood! Show your pics #5,012
Year one.
I girdle the locust trees with three passes around the bark. That usually kills them in a year.
Year two I drop them, limb them, drag them to the landing, stack them up like a pile of telephone poles, and as time permits, cut them into 16" lengths. Then I split them and stack them for a year.
Burn them year three.
I suppose I could just drop em, cut em and split them all in one shot, but I'd still let them dry for two years.
One thing neat about locust is you can burn in pretty green and still get pretty decent heat. But it'll soot up your chimney pretty badly.... been there, done that, bought the chimney brushes and learned my lesson. Only dry wood.
Locust is darn dense stuff. My sassafras and cherry fires tend to burn down in about 4-5 hours. The locust will go 11-12 hours.
What kind of Locust are you cutting? A Buddy of mine just took down two Honey Locust trees and gave them to me.
   / Tractors and wood! Show your pics #5,013
Pretty sure its black locust. No thorns at all. I have about 10,000 of them. So I'll be good on the firewood for a couple years.... :laughing:
   / Tractors and wood! Show your pics #5,014
Depending on how big and how seriously hung-up a tree is, sometimes a peavey or cant hook can be used to roll/rock it enough to get it to drop. I too frequently have to drop a hanger in sections, though. In awkward locations, I've occasionally had to accordion fell trees up to 8" or so...really big ones are too scary to do that, though!
I know what you mean- and in a couple of cases, in spite of trying the other methods, we really needed to rotate the tree to get it out of the "supporting tree", but hand tools were not enough, so I choked a tow strap around the trunk, and then wrapped it around it in the opposite direction from the rotation we wanted, and used either a come-along [most often], or winch [to hook onto the strap and and rotate the hung-up tree out of the canopy] anchored to a nearby tree, or rarely our little tractor with the box blade and bucket edge dug in to add traction and prevent it from getting dragged backwards toward the trees instead of rotating the tree.
It worked pretty well the several times we used it, but I forgot to mention, the butt of the tree pretty much has to be either resting on the ground or on the stump for this to work.
   / Tractors and wood! Show your pics #5,015
BTW, in addition to being good firewood (once it dries) Black Locust is incredibly rot resistant. It makes great fence posts, or a substitute for pressure-treated lumber for outdoor structures. It lasts longer than PT in most situations.
   / Tractors and wood! Show your pics #5,016
My horse pasture fence posts are made of black locust, extremely hard, and difficult to nail into. An impact driver and deck screws work well. The posts should last well after I am gone!
   / Tractors and wood! Show your pics #5,017
Year one.
Thank you. I have quite a few locust trees on my property, along with maple and cherry. It pains me to cut out a cherry or maple unless it is leaning into a field, dropped from a wind storm or too deformed to be used as lumber. We have a farm 20 miles away that has lots of beech, which makes pretty good firewood...easy to split and dries out quick. But it involves hauling, and trucks, and working off property. Ive ignored the locusts until now, but I will propably cut out a few now using your method.
   / Tractors and wood! Show your pics #5,018
I sold the whole machine because I needed a bigger machine. The other tractor is my Grandpas.
   / Tractors and wood! Show your pics #5,019
Just finished my oak sideboards, I should be able to get a full cord in there loose now. IMG_0101.JPG
   / Tractors and wood! Show your pics #5,020
I can get a little more than a full cord of 16"wood on my truck. Assuming our beds are the same length you can probably do a cord and a half. IMG_0427.JPG
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
ATLAS 10 1/2' DISC HARROW (A51247)
ATLAS 10 1/2' DISC...
UNUSED FUTURE FR70 69" LEVELER (A51248)
UNUSED FUTURE FR70...
