You have to be careful what you say with this crowd.I guess I could have been more specific that the tag was for Elk.
Got a laugh out me.Thanks.
Patrick
Patrick
The last two years I was able to stack 10cord each, white oak, separated by year, all started as standing dead. Equilibrium moisture content for around here is 13-15%.
Left, stacked two summers 13-15%. Right, stacked one summer 20-24%. Freshly split, no drying, 30-50%.
They didn’t, not left to dry in the sun.Pretty much the same results I get here in the Champlain Valley of Vermont. Non-Oak species I can fairly reliably get to 15-17% MC over one summer if I cut/split/stack in the spring. I can get a bit lower if I get it cut and stacked early enough. Mud season sometimes interferes with working early in the year, unless I get it done in the winter. (I actually prefer the winter for this sort of work... at least all but the stacking part. I don't enjoy that in any season, but particularly not in winter.)
I did not measure MC last year, but I'm betting last summer might have been an exception: the whole year was so continuously wet, that things might not have dried as well.
You're welcome, I'm always trying to keep things light! There is way too much negativity out there, usually for no reason other than to make the commenter feel better about themselves.I guess I could have been more specific that the tag was for Elk.
Patrick
Glad to see you back in the saddle hunt.Swimming pool?? WTH?
My biggest problem with firewood is a lack of hardwood trees, I have a spattering of oak and hickory and a lot of the time not in a place I want to cut them. I do have quite a few yellow poplars, AKA tulip trees down here, and gobs of sweetgum which makes up maybe half of my firewood, its not great but its not bad either!
PINE!! I have tons of pine which brings me to my post today. Finally getting past some medical problems that have been plaguing me for a while and got out my cutting gear today, first time since last summer I think! Again, most of my trees are pine, not so good for firewood but excellent for construction lumber and I have a couple projects I want to do so off I went! Just cut one tree today mainly to make sure everything was working properly after a too long layoff, and that's both my equipment and my body! Feels good so far (we will see about tomorrow) and my gear all worked as it was supposed to!
Butt diameter was right at 20" which is pretty normal for me here. About 50 feet up the tree split into two trunks which was good as I used those two trunks to stack my logs on till I bring my trailer over to haul everything off to my mill. Got 4 logs off this tree 2 at 12 feet, and 2 at ten.
Felt pretty good to get after it again!
The tree down
The base log was about all my tractor could handle, 13 feet and according to the log weight calculator 1256 pounds. Unless I was in 4wd the rear tire would just spin!View attachment 852623
And here is my start !!
I can tell when the wood is dry by how the piles stop shifting around as they shrink.4.5’ high. It shrinks to 4’ as it dries within the two year period it’s left out there.
I was thinking the same thing. He's been gone for over 2 weeks but all that somebody had to do was mention swimming pool...Glad to see you back in the saddle hunt
