Buying Advice Tractors and LED's?
   / Tractors and LED's? #21
Didn't realize I could do the leds that way. Are you using just leds like you'd get at Advance? I do agree, The m6800 did have some ugly lights. My buddy's 9960HDC has the new style like the grand L. They are the best factory tractor lights I've ever seen when looking straight back, before he added the bar. He did what I did and put a lightbar in between. Rightnow, the LED lightbar just knocks out the Factory lights on ours, we ran the light bar into the rear light wires, that way it uses the same switch
   / Tractors and LED's? #22
Oh, hey...you don't have to get the cube lights to replace the factor work lights. I actually opened the factory work lights on my Kubota and placed aftermarket LED bulbs that blaze the night in the housing.....Pretty neat setup. The Kubota factory housings for their cab tractors on the newer grands have a curve to them and are visually appealing....my old M6800 were just ugly squares and rectangles and a cube or circle led light would have been better.....so I worked pretty hard at maintaining the factory work lights on my Grand L....very satisfied with the power and looks.
View attachment 543200View attachment 543201
   / Tractors and LED's? #23
LED's are standard equipment on the Mahindra 2600 series. I haven't researched to see if they are putting them on others as well.
CFG Industrial MH12RX (A56469)
CFG Industrial...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
500 Gallon Fuel Tank with Pump (A55852)
500 Gallon Fuel...
John Deere 2520 (A53317)
John Deere 2520...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
