Tractor work pricing per hour
/ Tractor work pricing per hour #21
Yea, no way to swing that here. I can ocasionally push to $100/hr on some commercial accounts. Or sometimes it factors out at a high $/hr when applying my minimum charge.....but the average job, no way. And certainly not with a BX and a 4' mower. That setup around here.....and how productive it would be, you'd be looking at the $40/hr range.
My L3400 and 6' mower was a $60/hr machine
Prices are definatly regional .The cost of living in my area isnt cheap . I charge $ 95 an hour to do service work on Lawn sprinkler systems and I am not the most expensive . My equipment is a shovel .
/ Tractor work pricing per hour #22
LD1 has some good numbers and info on the cost breakdown. Travel times, wear and damaged equipment etc all has to be allowed for. And as many have said I also think you need to give the customer a price.
Personally I allow $35 a hour as minimum expense to run my Kubota L3560 and thats with me doing the maintence. Plus my wages, plus the insurance, truck trailor and what all as has been pointed out. My figure in mind is $80 hour minimum when calculating the price total to give the customer. Been averaging well over that so far.
I do have a nice set up with a full set of 3 hydraulics in back and the front end loader hydraulics have a diverter valve so I can run that front or back for a total of 4 in the back when needed with the 3 point grader blade. My point is that with the setup there is next to no wasted time climbing up and down or otherwise adjusting equipment. So there is no way to financially charge by the hour and compete with someone’s prices that is hand adjusting their attachments and wasting time and charging money to do so. Thus the bid by the job pricing.
Your probably going to mess up a few times until you get a bit of experience at pricing but it will work out if you learn from your mistakes
P.S. to keep it short I will say that so far my number one type of work that COST the most due to damaged equipment or whatnot is bush hogging. It’s hard to see everything in advance and what you miss can result in a bit more overhead cost in your operations.
/ Tractor work pricing per hour #23
First off moving equipment to a work site is generally 1 hour of your working rate.(often wavered for big jobs)
Now a $25k tractor costs just as much to repair as a $150k trackhoe with the only savings being fuel but the man operating still gets the (or should) wages.
So while a big tracked excavator is billed at , say, $140/hr a small tractor is probably fairly priced out at $80 or so/hr.(or more) bearing in mind the smaller machine can and probably will break more easily as the client will ask for the impossible.
I hired out my small tractor over the years usually charging close to $75/hr but mainly for delicate work that bigger machines could not do. (like spreading topsoil around a new construction or grading a drive.) and that generally as part of a larger contract that I was involved in.
For tougher jobs I'd get the client to rent a trackhoe that I'd operate at my usual hourly rates.
Remember that it takes as much labor at same rates to repair a big machine as the small ones. (and often even more) the only advantage is the weight of the components.
The smaller the machine the easier it is to break it!
Now of course mowing grass is a whole different ball of wax.
Flat rate, forget it, unless U really know the terrain. Clients will always claim that there are no rocks, stumps or old fence wire.
/ Tractor work pricing per hour #24
I dont believe that the $150k trackhoe and a 25k tractor are in the same ballpark at all on repairs and maintenance.
Typically trackhoes have really expensive hoses and fittings being that they are 4 or 6 wire stuff to handle the 5000psi.
They hold alot more oils, and filters are alot larger
Lots more grease points
Under carriage stuff, etc
Guys around here with ~20t excavators are in the $150/hr range.
Me and my tractor are $75/hr
And when it comes to digging, they are twice the cost per hour....but about 10x more productive
/ Tractor work pricing per hour #25
I think there's some incomplete information on what constitutes repairs.
There is, labor rates, and then there's parts fluids.
Clearly, the parts and fluids for the more expensive, construction-grade equipment is going to be more.
As to rates, I'd have to think that they'd also be higher for construction-grade equipment. Seems that the facilities and tools needed to work on larger equipment is going to be more costly, which requires higher labor rates to cover. And, the available mechanics would also seem to be more scarce, which also means higher rates (because their pay is likely going to be higher- figure in more schooling/training).
Not sure that anyone can dig down far enough to account for all the beans. Getting close is where you want to start and then monitor actual expenses and adjust (one should always be adjusting).
/ Tractor work pricing per hour #26
Big equipment cost more to operate no if ands or buts about it. You could probably scrap your tractor cheaper than a high dollar repair on a big piece of equipment.
/ Tractor work pricing per hour #27
A neighbor has an old International articulating tractor/backhoe, an industrial-grade machine. Blew out the rear boom cylinder. Seal kit alone was $750.
I was kind of trying to point out that I didn't think that the labor rates would be the same (for the reasons I stated); but, yes, overall operating costs are absolutely more expensive on larger equipment.
/ Tractor work pricing per hour #28
Absolutely the equipment needed to repair a smaller tractor is different. I had the dealer come out and do my 100 hr oil change. 25 hp machine, smallest one they make. They sent a HUGE truck. Turns out that guy came to do my oil change and then was on the way to repair some LARGE piece of farm equipment. I was told that the "trip" charge for me would be $x, and that is what they charged. I am sure that they thought was they would send a pick up truck or smaller truck to my job, but I happened to be on their way to a larger job.
In any event the guy that came out was a very experienced guy. I am sure his hourly pay was much more than what was actually needed to do my job. Again they honored the price they quoted me because it was not my fault this guy came out.
My point is that certainly you want a more experienced guy working on a bigger more complex repair. They make more money so the shop has to charge more to cover their wages.
/ Tractor work pricing per hour #29
I do work by the hour all the time. I get $50-75 per hour depending on the job. I have done jobs up to $700 at this rate. No worse feeling than being on the tractor for an hour or even two more than you calculated and thinking about the safety of the hourly rate. If I quote by the job, I add about 20% just in case so on most jobs it ends up costing the customer more.
/ Tractor work pricing per hour #30
Just curious.....
How do you handle customers when....
You tell them $75/hr.......and they ask "well how long do you think it will take you?
And how do you handle a customer if you estimated it taking you 4 hours.....so they are thinking $300......and it actually takes you 6 hrs ($450). Do you ever have them question that? Or say "I though you said it would take 4 hours....I only have $300"?
/ Tractor work pricing per hour #31
I put together a spreadsheet to figure my hourly cost.
For example:
HST filter cost $78 and needs changed every 200hrs.......................thats $0.39/hr
Trans, air, and fuel filter cost $90 every 400hrs.......................................$0.225/hr
Engine oil and filter.....$55..........200hrs ...............................................$0.275/hr
Super UDT oil............$150.........400hrs................................................$0.375/hr
Front tires ...........$400.........they last 1000hrs......................................$0.40/hr
Rear tires............$700...........they last 2000hrs.....................................$0.35/hr
Fuel. 2.5gal/hr.........~$2.50/gal............................................................$6.25/hr
Bushhog blades................$250.............replace every 200hrs..................$1.25/hr
Business insurance......Cost $600/yr.......put 200hrs / year on tractor..........$3.00/hr
Total tractor operating cost.................................................................~$12.50/hr
Factor in depreciation on tractor. Sure, the tractor will still have value after 5000hrs, but probably not without some major expense or rebuilds. So just assume tractor is going to be next to worthless at 5000hrs. Cost $20,000
So add $4/hr depreciation
Now add the truck and trailer cost....as its part of doing business as well.
Truck tires and trailer. Need them every 5 years. Which equates to 1000hrs of tractoring.
Truck tires...............$1000 ever 1000hrs approx on tractor.......................$1.00/hr
Trailer tires............Same $1000 ever 1000hrs.........................................$1.00/hr
Truck maintenance (oil, filters, brakes, etc).....$200/yr..............................$1.00/hr
Truck/trailer insurance.......................$1250/yr.......................................$6.25/hr
Truck fuel for hauling....500gal/yr........$1250/yr......................................$6.25/hr
Total truck and trailer expense..............................................................$15.50/hr
Truck and trailer depreciation, that at some point will need replace also. Probably $25k over 10years (and that may be low). So that factors about $12.50/hr as well.
Pushing $45/hr just to be able to be in business.
Sure, the truck and business expenses I correlate to hours based on the assumption of running the tractor for 200hrs a year for business. Obviously the more the tractor is used per year, the less the truck cost in terms of hours. But 200 is a good average for me over the last 3-4 years of commercial mowing.
And people wonder why my target is $75/hr.....or why I want $175 just to show up.
Guys running around with a broke down 1980's half ton, with an 8n and 5' hog, and no insurance, working for beer money.......no they dont have the overhead. You also never seem them on commercial accounts, or bank jobs to clean up abandoned properties, or realtor jobs for building lots, etc.
Organizing the operating costs like this is REALLY helpful to me. Thank you!
/ Tractor work pricing per hour #32
Obviously your numbers will be different than mine. Just plug in your numbers.
But its easy to overlook things, but it all adds up.
/ Tractor work pricing per hour #33
As others have said, know your operating costs. If you don't know how much it costs to operate your machine over the long haul you could very well go broke working at a loss. I estimate my operating costs at $35/hr. May not be the most accurate, but it's close enough for me & accounts for machine depreciation, expected maintenance & repairs, insurance, fuel & probably a couple things I've forgotten.
As this is my side gig my focus is trying to get enough work to make the machine pay for it's payment each month. I had a L3200 for personal use, then started side work. I quickly realized I wanted a cab if I was going to do much work & that the machine could pay for itself. So I upgraded to the L4060hstc for the cab & other bells & whistles. I'm lucky in that I can afford to sit idle & make the payment out of my pocket if it's a lean month or I have better things to do. I enjoy tractoring so that doesn't happen much.
I started off with the intent to charge $70-75/hr. That didn't end up working as well as I'd expected. People want a firm quote not a shifting target. My standard now is to figure out in my head how long a job will take. Expected hours + transport (15 min to an hour depending on roading vs trailering) * $75 * Pain the *** & uncertainty factor. The pain in the *** factor figures in more than I thought it would. Some jobs are just gonna suck, beat you or the machine up for whatever reason. People will still pay sometimes if you put in a high bid, but it pays for your pain. I've bid some jobs with higher unknown s a bit low. I figured they would pay me to learn a particular skill or techniqie. Id make less than normal in the pocketbook, but gain skill. Often that skill is estimating. Sometimes even bidding low I make noticably more than my usual rate, sometimes not.
Friends & family generally pay hourly at or slightly over my operating costs. There is high trust already there & they are getting a great deal, but then they owe me favors. I'm happy to work hourly commercially, especially if somebody has not well defined scope on what all they want done. But so far most everything has ended up being fixed price bids.
/ Tractor work pricing per hour #34
Just curious.....
Assuming you discovered some unknown or hidden obstruction you have a justifiable 'extra' charge.
If you simply knowingly under quoted just to get the job then the client is justified in being upset and probably will give you a bad name.
The proper way to handle this sort of dilemma is probably, ( like 1 hour into the job) stop and confer with client pointing out the discovery and get the OK to proceed, this way he knowingly accepts the extra costs. (worst is you lose 1 hr fee but not get a bad rep)
On the other hand some clients make it a game to entice and trap workers into low ball situations and find any or the smallest excuse to not pay.*
*Once bid and quoted in writing a job @ $12K that involved travel and lodgings and to witch I always added 5% to advance disbursements (common practice in some trades)
3 months later I was still in collection stages and they refused the travel totally and simply remitted a check for $10,000. and told me to sue them for the balance, and added it'll cost U more than your write off and you'll lose as well.
The owner was a lawyer (and a politician)
To him it was a game. eg a simple con artist with a law degree.
I later learned that I had to fly to that job was due to the fact that no locals would deal with him anymore.
/ Tractor work pricing per hour #35
You'll be busy at $65/hr... but you'll also be eating ramen noodles and scratching your head on how to make your bills...
Your not going to make a living with a tractor, it's not great at dirt work, it's not great at mowing lawns... it's a tool that has a specialty purpose, and nitch work is hard to keep busy at and should be priced accordingly, and $65/hr is horribly low... I charge $150/hr to my clients for my time and I push paper. My foreman makes $25-28/hr and I charge $130/hr for him... sounds extreme, until you see all the back end costs like the truck, tools, health care, retirement, insurance etc etc etc.... $65/hr is essentially $130k a year, but then subtract those truck/trailer/fuel/maintenance costs and all the others, think you'll find if your steady 40/hrs billable 52/wks a year, your making about $15k at most or $7.50/hr...
/ Tractor work pricing per hour #36
Around here you're going to be eating ramen noodles at any rate because there's not enough work to support you. And 65 an hour is still on the high side around here. There's multiple people that'll bring a skid steer out for that price. If dirt work was the goal they'll get more done in an hour than the OP. And there was no mention of the op wanting to do this full time. That makes it a little unfair to factor in cost not directly related to the job.
/ Tractor work pricing per hour #37
If I don’t like the job I’ll bid it to where I will like it or sub it out to someone that helps me out on occasion and still make some money.
When we were still building our place and before we had a tractor I hired a “buddy” to come mow about 10 acres. He blew me off 4 times with various lies from running over his moms cat to flat tires. He finally showed up unannounced while I was an hour away at Lowes with a 25 hp kubota and 4’ mower. He took off and spent about 3 hrs getting hammered drunk and then left. Showed up the next day and mowed another 1.5-2 hrs and got drunk again. In total he mowed around 3acres if not a little more. I asked him what I owed him and he said whatever I thought it was worth.
I gave him $100 he seemed like he wasn’t happy with that. Should’ve given me a price from the start. I wasn’t happy that he was here 5 hrs and only mowed 3 acres or he lied to me over and over. I hate liars. If I was having to pay him by the hour I would’ve been livid unless it was $20. We live about 45 mins apart
Brett
/ Tractor work pricing per hour #38
I dont call it tractor work , its just work . The tractor makes the job profitable . Grade and seed a new lawn , I bid the job at $ 2000 . If I did it with a rake and shovel or I do it with my tractor , its the same price . I have had people want to pay by the hour . And supervise the job , I give them my price and I work steady , not fast , not slow .
/ Tractor work pricing per hour #39
When someone mentions it's a business and is asking about employee payroll in the OP, it sure seems full time.
Either way, $65/hr is a crash and burn price for a business for part time unless your just trying to offset your own equipment costs...
/ Tractor work pricing per hour #40
I must've missed that the first time I read it. I hope his local market is better than mine. Otherwise he's going to fail at any price. And with no snow it's going to be harder to stay busy full time.
White 6182 12R Planter (A66285)
White 6182 12R...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
Mineral Feeder (A66408)
Mineral Feeder...
4' Mower Blade (A62679)
4' Mower Blade...
