Tractor Won't Start
/ Tractor Won't Start #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
I went to start my L3800, click on the glow plug then turn the key to the right, I hear the click but it won't turn over. Clutch is in, I even put it in neutral which I never have to, checked the rear PTO to make sure it was off. What am I missing?
/ Tractor Won't Start #2
First, check all battery and starter connections (including grounds) for corrosion and tightness. Then try it...
If that doesn't work, jump from another, known good, battery.
Thanks Roy. I did put a battery charger on it and it was reading full. I jumped the clutch safety switch, still won't start. I'll have to pull the battery terminals and make sure they are clean and check the starter/ground wires like you said. It's a new machine, 10 hours on it, 2 months old so who knows. Maybe someone forgot to tighten something?
/ Tractor Won't Start #4
10 hours? Let your dealer handle it.
I thought about it, but to get it up there, they have to pick it up since I don't have a trailer yet and they charge $75.
/ Tractor Won't Start #6
Have you checked the solenoid? If it's that, sometimes a slight tap on it can solve things. I did say 'slight tap'.
/ Tractor Won't Start #7
At 10 hours operation and only 2 months ownership...I think I'd insist they'll pick up the transportation costs. Can't hurt to call them.
Whatever you do, do not disassemble anything or any other work that could void your warranty!
/ Tractor Won't Start #8
Did you check all the safety switches (PTO, Seat,etc)? I have accidently left the pto on.:mad:
/ Tractor Won't Start #9
have you tried to rock the HST pedal back and forth a bit while holding the key in the start position. There is a sweet spot.
/ Tractor Won't Start #10
Rock the speed control pedal. There is a neutral safety switch associated with that. If it is going bad you should be able to rock that pedal and simultaneously turn the key. She should start if that is your problem. You should should also push in the clutch pedal while doing this.
I ended up getting it started. Not sure what I did. I did rock the HST and it didn't start, so I started checking all the wiring for the starter and ground like Roy suggested, still nothing. All the wires were tight and clen. There are 3 little fuse/relay blocks underneath the steering wheel. I pull a few I would guess relays and reseated them and wiggled a wire harness to make sure it was tight and it started. Not sure what did it. I didn't notice though that the engine turned over sorta sluggish. I shut it off, turned it back on and it started up normal. I noticed the sluggish starting before, but blamed that on the cold cause when it is semi warm out it starts fine. The battery has the green check dot on top of it and it was a nice green. Not sure what the real issue is here though. I guess I'll just keep my eye on it. That would be the last issue I thought i would have ever had. I bought new so I won't have these kind of problems.
/ Tractor Won't Start #13
No reason why you should have to pay for a trailer ride under warranty.
/ Tractor Won't Start #14
My dealer would not agree with your comment. Its a good dealer and he will perform all warranty work with a smile ... but getting the machine to/from the dealer is not free. Neither is his people coming to me.
MoKelly
/ Tractor Won't Start #15
MoKelly
Unless the dealer is an unreasonable distance I wouldn't agree to purchase a tractor under those terms. I don't find that to be an unreasonable expectation. They're likely going to make that money back in spades over time. My warranty time is supposed to flush out potential issues and should not come at any cost to me.
This is a CUT not an excavator.
/ Tractor Won't Start #16
Don't know if it applies to your tractor and you seem to have found the problem, but this is how I found out mine won't start if the mid PTO lever is down:)
/ Tractor Won't Start #17
MoKelly
My dealer is the same way. Thats why I will not buy from him again.
/ Tractor Won't Start #18
I have a different tractor but a similar problem.My L3240 was not starting good in the cold weather.It was traced to a loose wire on the glow plug relay so the glow plugs weren't working even though the indicator light was working.The relay was one of three in front of the steering wheel under the dash cover similar to your tractor.Not sure what the other two relays are for but it seems like one of them was probably causing your problem.Wiggling the wires seems to have been the cure.Hope it works fine for you from now on.
/ Tractor Won't Start #19
Having the dealer do the search and repair isn't just there obligation. It starts the paper trail on a warentee claim. The dealer gets paid from factory. Plus the mechanic is likely to check and test your entire wiring and electrical. Just in case it was built on a Fri. afternoon. ;)
I think I wouldn't hesitate to call the salesman that sold it to you. Tell him if he can't get the service dept. to come out and fix or pick up the tractor N/C he can kiss any future sales goodbye.
Maybe I am assuming too much. I know when I purchased the tractor, if I wanted them to do the maintenance I would be responsible for bringing the tractor to them. If they had to pick it up, they would charge me $75 for pickup and delivery. Maybe if it is a warranty thing, they may do the pickup and delivery. They are about a 1/2 away from me.
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
Gehl Mix-All 95 Grinder Mixer (A66408)
Gehl Mix-All 95...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Cute Electric Car (A62679)
Cute Electric Car...
