Tractor won't start...
   / Tractor won't start... #1
fireonthealtar
Hi all first post. I have a NH 1715 Was running fine 2 weeks ago when I parked it, but today when I went to start it I can hear the starter whining but the engine does not turn over. Also I was wondering if it could be a safety switch or something so when I engage the pto I get the same thing. Could this be the issue or any ideas on where I need to start.
Thanks
Chris
   / Tractor won't start... #2
Sounds like you have a stuck or broken Starter Bendix. (This link is not in direct reference to your starter, part # etc.) Sometimes they just need cleaning a/o lubrication. It's easy to pull the starter off & check it out. Remove the negative battery connection first. Some bendixes are engaged directly by the solenoid & some by centrifigal force. If you don't have a dealer nearby, or even if you do, any starter/alternator shop can fix you up. MikeD74T
Thanks Mike I will check this.
Chris
OK...help out the mechanically challenged. I took two bolts out of the starter, why will it not come off? Shouldn't this be similar to a car?
Thanks
Chris
   / Tractor won't start... #5
Unless there's another bolt I'd say the paint bond or rust if it's a tight fit is holding it in place. Put the bolts back in a couple of turns loose & give a whack with a rubber hammer or try a chisel between the starter & block. If you can't take it apart with a hammer it was never meant to be fixed ! Miked74T
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A51692)
2006 Ford F-550...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2019 Nissan Versa Sedan (A51694)
2019 Nissan Versa...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A53426)
2014 HINO 338 26FT...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
