Tractor wont start with new battery and starter.
   / Tractor wont start with new battery and starter.
Hey guys. I'm going to die a video in the week. How to integrate test the amp draw. I have a digital multimeter.
   / Tractor wont start with new battery and starter. #13
I agree. I had a Belarus that acted like that. Always needed to use the decompressor to get it spinning. Finally got around to testing voltage drop through the starting circuit and found the master switch was wonky. Bypassed that (and then replaced) and it spun over and started without the decompressor.
   / Tractor wont start with new battery and starter. #14
In my opinion if it cranks with compresion release then will not turn when released its not hydro locked or head gasket possibly as stated bad battery or starter need to check amp draw when cranking
I agree with you on the starter being suspect. My neighbor thought hisbatteries were going on his JD2040. A month or so after replacing the batteries, we comfirmed it was the starter when we let the magic smoke out of.
   / Tractor wont start with new battery and starter. #15
how long did you let it sit unused?
   / Tractor wont start with new battery and starter. #16
Sounds like the wrong battery or a week battery was installed. It's not delivering enough current (Amps) under a load. This could also be caused by dirty/corroded connections. I would expect a tractor with a 1.4L diesel engine to need a 500-600CCA battery.
Have to agree with this post.
Check your battery's ground cable. Run a jumper from the negative battery bare post to a bolt on the engine or starter. You have to have those amps.
Can't tell you how many bad grounds have caused starting problems on my tractors. Finally bought new, longer ground cables for them all and attached them directly to the engine. Never a starting problem since.
Hey guys it nows runs a treat. The earth and positive straps were cracked so I replaced them and it now turns over without decompression. Thanks for the help guys.
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
2020 KUBOTA RTV...
John Deere skidsteer (A55788)
John Deere...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
