Tractor won't move.
/ Tractor won't move. #1
noble12
westport ma
iron horse
Hi Have a problem with my 224 Iron horse . Moving some dirt and just stopped moving. running goes into gear no grinding ,can start in gear and still won't move. Shut off in gear wheels lock in gear so it must be in gear . But if I put it to creep it will move but hardly.
/ Tractor won't move. #3
Yup, shifting to lower gear or range to get it moving is symptomatic of a slipping clutch. Given that dirt work was mentioned, the first thought was a burnt friction disc. But if you didn't notice the smell while you were working, there still might be the possibility of adjusting it back into working condition.
//greg//
I'll don't know how but will read more to find out how . Thanks for your quick reply.
/ Tractor won't move. #6
Ok, basically you have to study on the clutchpack diagram in the operator manual. There are three basic adjustments, which should be done in the correct sequence. If you don't have the books yourself, you should get some. But I'm pretty sure the Iron Horse is a rebadged Jinma. So the diagram and sequential instructions are also listed here a number of times in the Chinese tractor forum. Assuming you have a two state clutch, search for JM254 clutch adjustment. It's likely the same clutchpack as in your IHT.
//greg//
/ Tractor won't move. #7
IF you have a front end loader, it's frame is most likely mounted over the clutch access holes, so the loader sub frame needs to be moved to access the clutch adjusters...
Good luck.
Thanks I'll try to take the loader this weekend and look at Manuel let every know
/ Tractor won't move. #10
You may not have to remove your loader, sometimes you can just drop the part that covers the inspection holes.
Got the loader off tried to adjust clutch and nothing ,so bringing to shop and will let everyone know what is wrong, Thanks to everyone who commented .
Well tractor had to be split main clutch plate rivets holding it together broken off. Thanks Circle G Quick ship
/ Tractor won't move. #15
It's fortunate that they didn't score a pressure plate. Or did you resurface them anyway?
//greg//
Wooden chair (A64557)
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2015 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2015 CATERPILLAR...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
