Tractor won't move while in gear.
   / Tractor won't move while in gear. #1
AustinKP
Templeton, PA
Cub Cadet 104
I have a Cub Cadet 104. When I put it in gear and start to release the clutch, it starts to move but as soon as I let the clutch out completely, it has no power to the wheels. However, if I press the clutch back in a little bit, it will start to move again. There seems to be a "Sweet Spot" in the clutch pedal so to speak that the tractor will move. Any ideas? Bad clutch? drive gear bad?
   / Tractor won't move while in gear. #2
Does the Cub have a transmission disconnect on the rear to allow you to push the mower with out the transmission holding it back?
My John Deere has a lever on the back so when you pull it out the trans free wheel so you can push by hand. If it is left out drive will not engage.
Just a thought.
   / Tractor won't move while in gear. #3
Sounds like the clutch to me. If the engine died while releasing the clutch and the tractor drove n neutral then it would be your shifting forks.
2025 Swict 84in Bucket Skid Steer Attachment (A55851)
2025 Swict 84in...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
1449 (A57192)
1449 (A57192)
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
