Tractor won't move while in gear.
   / Tractor won't move while in gear. #1
AustinKP
Templeton, PA
Cub Cadet 104
I have a Cub Cadet 104. When I put it in gear and start to release the clutch, it starts to move but as soon as I let the clutch out completely, it has no power to the wheels. However, if I press the clutch back in a little bit, it will start to move again. There seems to be a "Sweet Spot" in the clutch pedal so to speak that the tractor will move. Any ideas? Bad clutch? drive gear bad?
   / Tractor won't move while in gear. #2
Does the Cub have a transmission disconnect on the rear to allow you to push the mower with out the transmission holding it back?
My John Deere has a lever on the back so when you pull it out the trans free wheel so you can push by hand. If it is left out drive will not engage.
Just a thought.
   / Tractor won't move while in gear. #3
Sounds like the clutch to me. If the engine died while releasing the clutch and the tractor drove n neutral then it would be your shifting forks.
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
Case 580D (A47384)
Case 580D (A47384)
