Tractor won’t start
   / Tractor won’t start #1
lp51
Honea Path S.C.
John Deere
I have a John Deere 5205 that won’t turn over. Jumped it out at solenoid and it turned over but didn’t start. Switch was on. Will a bad thermistor prevent it from turning over I know it will prevent starting.
   / Tractor won’t start #2
Welcome to TBN! I would repost this in the JD section.
Thanks for the suggestion
   / Tractor won’t start #4
Are trans & pto control levers in neutral or off position? Have you checked that all fuses are good IE no fuses blown. With ign switch in on position check for 12 volts at wire on fuel control solenoid on inj pump.
   / Tractor won’t start #5
On the bottom of the inj pump is a wire.. that wire goes up to a temp switch on the manifold..
Unplug it either from the inj pump or the manifold & replace the starter fuse..
It should start now.
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
2016 INTERNATIONAL MA035 (A48992)
2016 INTERNATIONAL...
Millcreek Manure Spreader (A49251)
Millcreek Manure...
2011 Ford F-250 Crew Cab Super Duty Pickup (A49339)
2011 Ford F-250...
2008 Ford F-250 Reading Service Truck (A46683)
2008 Ford F-250...
Brillion 9-shank Soil Commander (A47369)
Brillion 9-shank...
