Tractor won’t split stuck between clutch and transmissiin
   / Tractor won’t split stuck between clutch and transmissiin #1
Workin fool
Pa
John Deere 1020
Just did a clutch to engine split to check clutch plates and splines on John Deere 1020. I have no fluid going from transmission pump to front pump. Everything looked good in clutch. Put back together in a couple hours and started on transmission to clutch split. I can’t get it to separate. Drove a couple steel wedges on a raised area near shifters to put pressure on it. Checked twice to make sure all bolts are out. Anyone have any ideas or suggestions
Found the problem. Two bolts inside shifter cover
   / Tractor won’t split stuck between clutch and transmissiin #3
I was going ask if you knew about them. I've split a couple 2030 several times.
Also a bolt behind the transmission filter.
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
