Tractor won’t split stuck between clutch and transmissiin
   / Tractor won’t split stuck between clutch and transmissiin #1
Workin fool
Member
Pa
John Deere 1020
Just did a clutch to engine split to check clutch plates and splines on John Deere 1020. I have no fluid going from transmission pump to front pump. Everything looked good in clutch. Put back together in a couple hours and started on transmission to clutch split. I can’t get it to separate. Drove a couple steel wedges on a raised area near shifters to put pressure on it. Checked twice to make sure all bolts are out. Anyone have any ideas or suggestions
Found the problem. Two bolts inside shifter cover
   / Tractor won’t split stuck between clutch and transmissiin #3
I was going ask if you knew about them. I've split a couple 2030 several times.
Also a bolt behind the transmission filter.
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
2021 HITACHI ZAXIS 35U EXCAVATOR (A51242)
2021 HITACHI ZAXIS...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
