Welcome to TBN.
Any mower deck can use a mulching blade and typcaily they dont take more HP - just the serated blade and usually a plug in the chute. I use mulching blades on my Ferrris ZTR and no plug - the blades just shred the grass a bit finer.
Yes, all you need to tell them is you want mulching blades and the block off plate is just a cover over where the chute goes.
Personally I would get the standard mower and have them throw in a set of mulching blades and a block off plate that you can change out anytime and put the block off plate on it.
Look up "kubota mulching mower set up" on google and you should see what I refer.
Personally I would go with "gator blades" whcih are mulching blades and use the standard chute. The problem with the blocking plate is that if you are cutting long or thick or wet grass clumping will occur and clog up the bottom and clump the grass. Its better to cut it as fine as possible and discharge the clippings.
Well I tried to look up "kubota mulching mower set up" on google and didn't find a thing. Is there a part number for the kit or a link to a site? Thanks for helping me with this i'm new to this.
