Tractor will not start
/ Tractor will not start
I need to put a lower hose heater on. After I change the clutch and the glows are not working. This tractor has just gone to hello. I need to change this all out and then keep up with adjustments or it will not be around in 5 years. But I do believe that the clutch was near out and the 4x4 was repaired before I bought it. Now that I almost have it paid off I don't want to get a new one. I can fix this one for years.
Hey sound guy. That sounds about right. There are many things that are done that don't need to be done. The shifter really is not any help. I have to stop and out it into reverse and change gears. It would be just as easy to change gears to reverse. To many times I have needed to use both hands off the wheel when I really need to have one on. It's like having an eject button and command on a cd player. You have to get up to get the disc anyway.
/ Tractor will not start #23
yep.. i've never understood why they made their onboard hyds capable of being deadheaded BY DESIGN... seems backwards... just sayin...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2022 John Deere 1025R (A53317)
2022 John Deere...
CFG QK16R (A60463)
CFG QK16R (A60463)
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
Striker TNB-4M Hydraulic Breaker (A60462)
Striker TNB-4M...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
