Anonymous Poster
Epic Contributor
- Joined
- Sep 27, 2005
- Messages
- 29,678
Hello Everyone, Today while grading my right front wheel fell off my New Holland TC 24D.
I was moving down a steep slope and almost to the bottom and bam the wheel folded under! I quickly dropped the loader bucket and caught the tractor before it tipped over on its side. Upon examination I found no lug nuts on the axle or the rim. I found three of them later all very chewed up, even the lug nut holes in the rim had been reamed wider. I was able to take two lug nuts from the other front wheel and they went in ok and limped to an open flat area. I then visited Home Depot hoping to find some of these lug nuts, no dice.
I settled for some 7/16? bolts that looked like they should work but when I tried to get them in the holes the damage proved to be too severe. So I need to finish my project before the city/county finds out what I have been up to. I will go back to Home Depot and get some longer bolts and some nuts and then drill out the holes. I think this should work for a couple days unit I can get it to the dealer.
My question to all is: has this happened to you and if so will New Holland cover it under warranty. I checked the rest of the wheels all were good except for the left front wheel it needed to be tightened. I have had problems with the front axle bolts coming loose on the differential but I took care of that.
I could have been hurt bad if that tractor had rolled over. I urge everyone to check the lug nuts on their tractors ASAP! It was very scary and now I am worried on who is going to pay of the repair. /forums/images/graemlins/confused.gif
George
George
