Tractor Sizing TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #142
If it wasn't for the traction and weight, I couldn't have pulled my 2 shank ripper about 16" deep on hard clay.
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #143
If it wasn't for the HP and torque you couldn't have pulled it either.
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #144
Oh, and don't forget the 4WD that was engaged. Without that you wouldn't have pulled it 2 feet.
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #145
A good thing to look for when looking at tractors is at what RPM does the engine make its max HP. I would chose a engine that makes its maximum horsepower at the lowest RPM. I would chose a 40 horse that makes its max HP @2000RPM over a 50 horse that makes its @3000RPM
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #146
Implements usually come in HP per when it comes to sizing.
I’ve never seen weight per when it comes to matching tractor and implement.
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #147
Check out ditch flails. They all have a minimum weight for the tractor.
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #148
Ditchbank/ boom cutters are a different animal. Their weight distribution is so skewed it's amazing they don't require even more tractor weight than they do. I've been running a Hardee ditchbank cutter for close to 30 years and I can say it's by far the most dangerous implement that I own. It's not nearly the beast behind my 100 HP tractor that it was behind my 55 HP tractor. Hmm, wonder why that is? Maybe that the higher HP tractor weighs more? But I see these flail mowers and knowing what I know about running offset weight I'm waiting for the tractor in the ditch or tractor over the bluff or tractor in the pond post. They are awkward, especially behind small tractors.
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #149
Your 100 HP tractor is only 90 HP, but if you got the 100 HP model it would be the same exact weight.
At some point HP goes up to handle the additional weight, but more HP often does not mean more weight. Suggesting more HP gets more weight could seriously mislead some people reading this, especially those who may be new to tractors.
For instance, the TYM 2515 is just under 3000 lbs and 25 HP. The JD 2038r weighs 20% less and has about 50% more HP.
   / TRACTOR WEIGHT as ONE (1) CRITERION in TRACTOR SELECTION #150
For actual farming operations where you are using ground
engagement equipment doing actual plowing and tillage with turn plows and harrows weight is always your friend.
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
S/N: 1240824 (A55853)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
case 370 glass door never installed (A56435)
case 370 glass...
