Tractor Sizing TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #121
Post #110: The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for recommendations.
Your question is answered in Post #103.
Thank you for your time, but that didn't appear to directly answer any of the questions I asked. I'll allow that I may be having a particularly dense moment, something I am all too capable of doing, so if you are willing can you quote my question then extract the part of post 103 and 110 that you think answers that specific question.
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #122
Heavier tractors are constructed on larger frames and longer wheelbases making them heavier, which helps maintain heavier tractors upright when applying loads, especially FEL loads.
Heavier tractors have wider wheel stance, increasing stability.
Heavier tractors have FEL lift and Three Point Hitch lift in proportion to weight. Greater FEL lift is the #1 reason compact tractor owners trade up to heavier models.
Heavier tractors are built with thicker steel and thicker axles to withstand greater stress. As a newbie operator you are more likely to bend a light tractor than a heavy tractor.
Heavier tractors have larger diameter wheels/tires, increasing ground clearance. Larger rear wheels are an additional form of gearing. Therefore, heavier tractors with large diameter wheels/tires have more tractive power pulling ground contact implements, pushing a loader bucket into dirt and pushing snow. Larger wheels and tires and a longer wheelbase permit heavier tractors to bridge holes, ruts and tree debris with less operator perturbation.
Tractor weight provides most tractor "grunt" defining tractor capability. Horsepower is needed too but horsepower is less important. Tractor horsepower moves up in priority when considering power for PTO-powered implements like Bush Hogs, but remains secondary to sufficient tractor weight.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second and (narrowly) rear wheel ballast third.
Horsepower is what the wheels also see. Big wheels and no horsepower don't pull much.
Would the tractor designers consider footprint and ground compaction in the design for horsepower or pulling ability?
Tractors are usually designed to handle attachments. You can bend big heavy ones too.
If one needs more attachment capability you pick the tractor that is suitable.
Tractor stability is based on center of gravity, not weight.
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #123
"How much bare tractor weight do I need to pull 4-5 [sic- foot] implements?" Depends on the implements. 2,000 pound tractor? That is tiny. Stick to 4 foot implements. Bush hog? Your 2,000 pound tractor can pull a 5 footer around, but needs more than the probably 18 hp PTO that a 24 hp tractor will produce to run it effectively.You need 3,500 pounds of tractor weight to effectively use a 5 foot ground engaging implements like a box blade (think L series with loaded tires and an FEL).
Our L3901 is great at what it does, but to really move stuff the MX5800 at almost twice the weight and horsepower is a beast
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #124
When you fill a 5ft box blade on a 24-26hp tractor you will find out in a hurry if you're tractor has enough tractor weight to pull it, weight = traction when pulling ground engaging implements..
That touches on my question. Weight=traction. I get that. How do I know how much weight it takes to draw a box blade with ripping tines through soft soil with some roots in it? The dealers in my area have been selling 5' blades with my desired weight tractor, so that leads me to believe that the tractors are heavy enough for those blades.
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #125
Maybe... Depends how many and what size roots.. For the most part the small tractors will pull a 5ft box blade with soft material but IMO, you can get more done with a 4ft on a SCUT with less rippers requiring less weight and less traction..
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #126
Many other factors at work here too. What tires are you getting? Are you going to "load" them or put on rear wheel weights? What is the soil like there? ALL of these things can mean a lot as to how well your implement/tractor combo will work for this application. You already mentioned not much hills, and this is a good thing in your favor for many reasons besides traction. Safety being the largest.
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #127
Agreed..
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #128
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #129
Yikes! That would be fun. :laughing:
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #130
Dranrab,
I won't speak for Jeff or any of the others who posted. You have already received excellent advice. Since I was in your position not too long ago I would like to add that now that I am actually using a tractor frequently all of the advice I received makes more sense.
Let me give you an example; I went with a L4330 HST with Cab. I nearly purchased a Mahindra or a Kubota L2501 as I didn't have any real reference for what I needed. Both of the ones I started looking at would have been inadequate for my needs. I just didn't know that at the time.
I found some dealers to be excellent and others to be vague or outright misleading. If I asked could the L2501 pull X attachment the answer was sure, you could do that. Which may technically be correct but not practically. If I asked "could I pull x attachment with the L2501 QUICKLY" the answer was usually no. You have to know what you want to do, what you can afford and what you have to compromise on to fit your budget/space/trailer,etc.
As Cathy stated she can get the job done with her L3901 but to "Really move stuff the MX5800 at almost twice the weight and horsepower is a beast". Some things that I would like to do could benefit from a larger tractor then what I purchased. Such as bush hogging. I would love to pull a larger mower but the cost of the extra horsepower and larger bush hog made it unfeasible for me. Plus I didn't really need that much weight and also don't need anything larger that makes getting in to the shed or around trees more difficult so I compromised on speed in favor of cost, space and weight.
The speed at which I am able to get work done was very high on my priority list. Had I gone with the 2501 I could likely still get the work done but not in a reasonable amount of time. By now I would have sold or traded it in and gone through the expense of purchasing again.
In short (too late for that I know), if all you need to do is pull a box blade then find out what size you need to pull, how long it will take with that size and if that is your only criteria find a tractor that will pull it well. Just don't get too focused on one task. I never thought of using pallet forks on my tractor but now it is one of the most used items.
Good luck. Let us know what you decide.
(1) 5' X 4' TRAILER TAILGATE (A57192)
(1) 5' X 4'...
1994 International 3800 Bus (A54814)
1994 International...
2020 CATERPILLAR 416 F2 BACKHOE (A52707)
2020 CATERPILLAR...
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
60" EXCAVATOR BUCKET (A52707)
60" EXCAVATOR...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
