tractor vibrating real bad
/ tractor vibrating real bad #1
rickv3
chelmsford
1983 1710 ford compact 4x4 diesel
Hi guys I'm back once again tractor 1983 ford 1710 compact tractor, once 3pt hitch is at it's highest position with snowblower the tractor vibrates very bad lower snowblower to lowest position vibration stops, pto not on, past the highest position on the 3pt hitch the vibration stops but front loader does not work, any help would be a appreciated, thanks
Rickv3
/ tractor vibrating real bad #2
Using the 3pt in the highest position, will cause the relief valve to activate and feed back pressure to the loader and will cause problems.
When not using the 3pt, put the lever in neutral.
If you use a pressure gage, you can see the result.
I've always had the pto to the highest position, for ground clearance of the implements, where is neutral position, I'm new to all this
thanks
Rickv3
/ tractor vibrating real bad #4
Did you mean the 3pt?
Neutral should be where the lift arms neither move up or down, and fluid is just flowing through the valve.
Your tractor could be different.
Like I said, if you install a pressure gage in the flow path, and if you are using fluid somewhere, the gage will show the pressure.
I've just notice one thing today, when implement is raised the implement slower lowers by itself, my tractor has a lever I think it's called control lever, move it down to a stop position which lower s to the ground, move up to an area that has a grove and I take it that this is the top position, you can also past that point and the implement will go a little higher and the vibration will also stop but the hydraulics for the front bucket will not function, hopes this clarifies a little thanks for the help
Rickv3
