Tractor to baler pigtail
   / Tractor to baler pigtail #1
Flexrake
Opp,AL
Kubota 4900
Who makes pigtails to plug one end into baler and other end into the tractor for use with the rakes that is pulled between the tractor and baler so you can rake and bale n one trip?
   / Tractor to baler pigtail #2
What?
Going to run a tractor to pull a FLEXRAKE 10 wheel v rake that has a shaft running thru the main frame to drive the baler that's pulled behind the rake. This way I can rake and bale at the same time. I want to buy a wiring harness (pigtail) that's about 25' long that will plug into the tractor, run then back to the baler and plug into the baler. I've seen them but I don't know where to get one.
   / Tractor to baler pigtail #4
You might find a wiring pigtail here.
334-937-0024 or visit flexrake.net.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2016 Ford F-150 Pickup Truck (A55973)
2016 Ford F-150...
LOT: Assorted Clamps (A59076)
LOT: Assorted...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
1453 (A57192)
1453 (A57192)
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
