Tires Tractor Tires
   / Tractor Tires #1
eastpointer
Souris, PE
Kioti CK 20 S
I have a Kioti CK 20 and am looking for a set of turf tires for it. Does anyone know if the rims and tires of a Ford 1220 tractor would fit the tires are near the same size and they are both six bolt pattern. I am just wondering if the hubs are a generic size ??
   / Tractor Tires #2
You need to find out what Kioti uses and match it exactly to there size tires ,if you don't then you could ruin the tractor drive train because of over-under drive between front and rear axles.
   / Tractor Tires #3
The CK20S Turf sizes are 23x8.5x12 Front tires and 33x12.5x16.5 on the rear.
The rears are 6 lug and the studs are 5.5" center to center (approx)
The fronts are 6 lug, the studs are 4.75" center to center (approx)
BTI
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
toro turf sweeper (A50324)
toro turf sweeper...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
