Tires Tractor Tires
/ Tractor Tires #1
eastpointer
Souris, PE
Kioti CK 20 S
I have a Kioti CK 20 and am looking for a set of turf tires for it. Does anyone know if the rims and tires of a Ford 1220 tractor would fit the tires are near the same size and they are both six bolt pattern. I am just wondering if the hubs are a generic size ??
/ Tractor Tires #2
You need to find out what Kioti uses and match it exactly to there size tires ,if you don't then you could ruin the tractor drive train because of over-under drive between front and rear axles.
/ Tractor Tires #3
The CK20S Turf sizes are 23x8.5x12 Front tires and 33x12.5x16.5 on the rear.
The rears are 6 lug and the studs are 5.5" center to center (approx)
The fronts are 6 lug, the studs are 4.75" center to center (approx)
BTI
(3) FANS (A63291)
(3) FANS (A63291)
Caterpillar 615C Scraper Service and Parts Manuals (A63117)
Caterpillar 615C...
Kubota L3901HST
Kubota L3901HST
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
